Michael 111 Guest
07-10-2007, 9:48 Subject: Spot the Mistake: Find the Error in This Image |
It may not be a VW, but it's a turbocharged diesel.
I hope that something can be recognized  .
http://img527. " color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusätzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema für andere Leser nutzlos!
Bitte nutze 'Attachment hinzufügen' bzw. das Upload Forum hier. /my.php?image=ladedruckxl7kz3.gif
Translated on 20-09-2026, 11:36.
Joined: 04/12/2002 Posts: 18126 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
07-10-2007, 10:31 Subject: Spot the Mistake: Find the Error in This Image |
What kind of tiny turbocharger is that, which is supposed to build up a pressure of about 700 mbar at 1220 rpm?
The injection time also seems unrealistic. 1ms at 1220 rpm would correspond to an injection duration of approximately 7° crank angle. And in a common rail engine, the rail pressure wouldn't be particularly high at 1220 rpm either...
What engine are we talking about? Is it a 1.3L CDTI? Is the software original, or has it been modified in some way?
My guess: there are problems here with a tuning file, possibly modified by an inexperienced user. Did I guess correctly?
Translated on 20-09-2026, 11:37.
Profile PM WWW Garage |
Jochen_145 Guest
07-10-2007, 11:00 Subject: Spot the Mistake: Find the Error in This Image |
What kind of tiny charger is installed there that is supposed to build up a pressure of about 700 mbar at 1220 rpm?
Yes, you can want a lot of things, but what you actually get...
And with a CR engine, the rail pressure at 1220 rpm won't be particularly high either...
Yes, you can have the maximum possible rail pressure at 1220 rpm, but you have to forget to inject fuel, otherwise the rail pressure will unfortunately drop again  .
My guess is: there are problems with a tuning file, possibly modified by an inexperienced user. Am I right?
Yes, I would agree with that as well...
I'm sorry, I probably just had breakfast with a clown, but I took the headline ironically.
Best regards, Jochen.
Translated on 20-09-2026, 11:39.
Michael 111 Guest
07-10-2007, 11:13 Subject: Spot the Mistake: Find the Error in This Image |
Watering can tuner
is correct
The tuning file is from here.
database-for-chiptuning.de/ [Edit Admin Link - added for SEO purposes]
It should be  30kw more.
probably more like 3kW
ENGINE ---> 2.0 HDI RHW, 80 kW, 270 Nm.
from my Suzuki Grand Vitara XL7.
Translated on 20-09-2026, 11:41.
07-10-2007, 11:22 Subject: Spot the Mistake: Find the Error in This Image |
aha  well, there must be a reason why there's no name or address in the "About Us" section on the page or anywhere else  .
Denic states who operates the server.
http://www.denic.de
Translated on 20-09-2026, 11:42.
Michael 111 Guest
07-10-2007, 18:15 Subject: Spot the Mistake: Find the Error in This Image |
Aron Blaumann
Joined: 10/26/2006 Posts: 440 Karma: +5 / -1 Location: KC
07-10-2007, 19:37 Subject: Spot the Mistake: Find the Error in This Image |
"Did you log the fuel rail pressure? It would be helpful to see how it changed. The injection duration looks really messed up (what does the MAF sensor say?). My engine (same engine, but with 8 fewer valves and a PF version) runs at 1000 rpm with just under 2 milliseconds of injection time, and at 4000 rpm with 1350 bar of pressure, it only uses 750 microseconds." Peugeot 307 (T5)1450kg Speck, RHS, MJ2002, 138g CO2 inkl. Korken im Auspuff und goldene Möhre 2006, MAF+50% mit passender Dieselmasse. nunmehr 370000km
Translated on 20-09-2026, 11:43.
Michael 111 Guest
07-10-2007, 19:47 Subject: Spot the Mistake: Find the Error in This Image |
However, there is air mass present, and the rail pressure  is.
Yes, that looks really bad.
Aron Blaumann
07-10-2007, 20:02 Subject: Spot the Mistake: Find the Error in This Image |
Michael 111 wrote: | However, there is air mass present, and the fuel rail pressure is low.
Yes, that looks really bad | .
Ha, now that you mention it  ... can't see the forest for the trees. I was already wondering what people mean when they talk about "Susi" in that context. Peugeot 307 (T5)1450kg Speck, RHS, MJ2002, 138g CO2 inkl. Korken im Auspuff und goldene Möhre 2006, MAF+50% mit passender Dieselmasse. nunmehr 370000km
Translated on 20-09-2026, 11:44.
