Reprogramming AFN MSG for 1Z
Jens 16syncro
Karma: +2 / -3   Thank you, like it!
Post27-08-2007, 11:49    Subject: Reprogramming AFN MSG for 1Z Quote
Hi there,
If I'm going to need a modified dataset anyway (let's call it "chip tuning" for simplicity), can I upload the (modified) dataset from a 1Z engine onto an existing MSG module from an AFN engine?
1Z and AFN, both equipped with MSA15 and WFS.
Background:
I converted an AFN engine to a 1Z and am currently using a 1Z MSG (engine control unit). However, I still have the original AFN MSG. Would it be possible to use this as an "alternative" MSG with an adjusted data set?
Jens.
Marcus "Ar Gwenn": Für uns sind Leute arm, weil sie mit einem Eselskarren unterwegs sind, für sie sind wir arm, weil wir ein Leben lang dafür arbeiten und Geld verdienen müssen, um uns im Alter von wildfremden Leuten pflegen zu lassen.
Translated on 12-08-2026, 11:41.
Post27-08-2007, 11:51    Subject: Reprogramming AFN MSG for 1Z Quote
As far as I know, the 021 GG is a replacement for both 1Z and AFN, and it's also compatible with an MSA15, so it should work.
Translated on 12-08-2026, 11:42.
Rudi
Post27-08-2007, 12:48    Subject: Reprogramming AFN MSG for 1Z Quote
GG replaces only AF and BF (i.e., 1Z and AHU).
In the AFN system, it was designated as 021GH.
It is possible to reprogram the device (either by changing DF to BF or GH to GG; cross-channel switching is not supported).
Rudi
Translated on 12-08-2026, 11:43.
Post27-08-2007, 13:09    Subject: Reprogramming AFN MSG for 1Z Quote
UPS
Well, I ended up having to pay for Erwin (siehe Fehlerdatenbank) twice.
I still can't memorize it.
No new posts Reprogramming the AGR control? Diesel Engine Technology
No new posts Reprogramming Audi A3 81kW AHF / Central Locking System Diesel Engine Technology
No new posts Reprogram ECU for More Power On-Board Diagnostics (OBD)
No new posts Steuergerät von TDI umprogrammieren ohne Hardwareveränder Diesel Engine Technology
