ttns4 Guest
06-12-2002, 13:08 Subject: Ulf's Draft Calculation Tool - Loading Test |
Hello, I'd like to download the latest version of the Ulf's ventilation calculator, but either I'm too stupid, or something's wrong with my eyes.
Where and how can I get it? (I wanted to download it briefly in the store  ).
Thorsten.
Joined: 04/12/2002 Posts: 18131 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
06-12-2002, 13:22 Subject: Ulf's Draft Calculation Tool - Loading Test |
Okay, so, clicking the link should be enough; then Excel with the calculator will open in the right frame.
Do you even have Excel or StarOffice?
It works great for me.
Profile PM WWW Garage |
haehnlein Schrauber
Joined: 08/22/2002 Posts: 877 Karma: +6 / -0 Location: Griesheim
06-12-2002, 15:08 Subject: Ulf's Draft Calculation Tool - Loading Test |
Hi!
My Netscape 7.0+doesn't open Excel either! But Internet Explorer does (->I still use Netscape as often as possible to avoid supporting Microsoft  ). Netscape sometimes experiences JavaScript issues with the website www.dieselschrauber.de.
Best regards, Christian.
06-12-2002, 15:39 Subject: Ulf's Draft Calculation Tool - Loading Test |
Okay, my development computer at home uses Netscape 6.2.1 for the website, and there are no problems with JavaScript on that system.
Can you understand how and under what circumstances the problem occurs?
With Netscape, the spreadsheet will only open if the settings are correct, meaning that the file type 'xls' must be associated with a suitable spreadsheet program.
If necessary, you can also save the file and open it manually outside of Netscape.
haehnlein Schrauber
06-12-2002, 16:47 Subject: Ulf's Draft Calculation Tool - Loading Test |
Rainer K. wrote: |
hm, my development computer at home, which I use for the website, runs Netscape 6.2.1, and there are no problems with JavaScript on it | .
Hi Rainer!
"Until yesterday, I was having a problem with the small "back to homepage" window. With Netscape 7.0, I couldn't click on anything in that window (but it worked fine with Internet Explorer). However, it's working again today! Maybe my Windows 2000 is about to crash (which is pretty normal, I guess!)." I don't have any problems with Linux, at least.
When I save the Netscape download manager as an xls file, it is not recognized as such!
ttns4 Guest
10-12-2002, 12:52 Subject: Ulf's Draft Calculation Tool - Loading Test |
Hello Rainer,
I seem to have a problem at work.
The main page keeps crashing when I try to load it.
After that, I have to manually close Internet Explorer, which closes all open Explorer windows.
I'm trying it again from home.
Is the link to the ventilation calculator only available on the main page?
I can't reach it.
(It's not likely to be a problem with processing power; we have quite generous equipment from the company.)
Bye Thorsten.
TDIBubi Guest
10-12-2002, 13:06 Subject: Give me your email address and I'll send it to you as an attachment! |
Please give me your email address and I will send it to you as an attachment!
Arne Guest
10-12-2002, 13:36 Subject: Ulf's Draft Calculation Tool - Loading Test |
Right-click on the link and select 'Save target as...'
arne
ttns4 Guest
10-12-2002, 18:32 Subject: Ulf's Draft Calculation Tool - Loading Test |
Hello everyone, again.
'From home, I was able to download the software without any problems.'
Thank you for your support.
Thorsten
