Blower Resistor for VW Polo 9N
golf3schrauber
Post28-08-2007, 7:54    Subject: Blower Resistor for VW Polo 9N Quote
On a friend's Polo (9N, 2003), the blower motor only works on setting 4.
I think the pre-resistor is defective.
Does anyone know where it's located? Is it available as a separate part?
Gruss Oliver.
GolfIII,1Z,66KW,von94 mit 500tKm !
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 16-08-2026, 6:34.
Maxx1278
Avatar-Maxx1278
Post28-08-2007, 8:21    Subject: Blower Resistor for VW Polo 9N Quote
In the documentation, I found a resistor connected to the fan.
It should be for the fan speed.
6Q0 959 263 A costs EUR 27.70 excluding VAT.
Sure, Maxx.
Translated on 16-08-2026, 6:35.
golf3schrauber
Post28-08-2007, 9:51    Subject: Blower Resistor for VW Polo 9N Quote
Thanks for the information. Were you able to find out where this resistor is located?
Is the fan itself attached, or is it detached and located somewhere else?
Gruss Oliver.
Translated on 16-08-2026, 6:36.
Maxx1278
Avatar-Maxx1278
Post28-08-2007, 10:10    Subject: Blower Resistor for VW Polo 9N Quote
According to the drawing, the part should be located to the left of the fan.
Sure, Maxx.
Translated on 16-08-2026, 6:37.
golf3schrauber
Post28-08-2007, 19:05    Subject: Blower Resistor for VW Polo 9N Quote
I think I'm going to have to remove the entire dashboard assembly, including the glove compartment, first.
From down here, I can't see anything.
I can see the two cables of the fan motor, but they seem to be going upwards rather than downwards.
Maybe someone else has an idea.
Gruss Oliver.
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo combination instrument panel, 1998 to 09.99 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cooler fan motors, switching stages, pre-resistors Transmission, Chassis, Body & Interior
No new posts 3B5: Troubleshooting and Common Issues On-Board Diagnostics (OBD)
No new posts Auxiliary Heater VW T4 Fan Rear Transmission, Chassis, Body & Interior
No new posts Blower Relay J323 - Replacement & Parts On-Board Diagnostics (OBD)
