What more can the VAG1551 do?
AndyO
Post08-12-2002, 16:18    Subject: What more can the VAG1551 do? Quote
Although I have extensively read the forums on vehicle management, I still don't know whether I can manage my vehicles or not. Only a fraction of the vehicles are marked with 'Yes' in the compatibility list of the Vehicle Explorer.
To the best of my knowledge, there is a VAG 1551 measuring device in the workshops. It has been used for years to measure all types of vehicles from VW, Seat, and Audi.
Which standards are supported by the VAG 1551 (OBD I and OBD II)?
Some of the vehicles are likely compatible from the mid-90s onwards. Which company established this standard (Bosch?)? How can I identify the compatibility based on the components?
I suspect that there are several different connection cables for the VAG 1551, designed for various vehicles. As far as I know, these cables only adapt to the different pin configurations and provide electrical isolation. The communication protocols must be built into the VAG 1551 itself.
Can someone clarify this?
Translated on 08-07-2026, 19:46.
Rudi
Post08-12-2002, 22:46    Subject: What more can the VAG1551 do? Quote
Hello Andreas,
The VAG testers 1551 and 1552 (a smaller version of the 1551 without a printer) are primarily testing devices from/for the VAG group.
They support the company's specific requirements for vehicle diagnostics.
They are comparable to VAG-COM in terms of functionality. Standardized OBD functions are not really supported.
There are only two connection cables for the devices. In newer vehicles, the 16-pin OBD2 connector is used, while in older vehicles, the diagnostic cable terminates in three ends, which are either single-pole or double-pole.
The connector pins provide 12V, ground, K-line, L-line, and (for older control units) turn signal evaluation.
Extensions for CAN or RS422 are available, but they are quite rare.
Best regards, Rudi.
Translated on 08-07-2026, 19:49.
No new posts BLS - Erratic idle when AC is on - and more Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Pa 3C BMR Won't Start: Error Code 004160 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Radio Problem: Fix for 8L Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Q7 3.0 TDI: Regeneration Problems & Solutions Diesel Engine Technology
No new posts ASR Not Working After Instrument Change? Transmission, Chassis, Body & Interior
No new posts Boost Pressure: Does 20% More Mean 20% More RPM? Diesel Engine Technology
No new posts Clean LMM: How to Clean Your LMM. Diesel Engine Technology
