ABS Control Unit for Passat: Alternatives & Replacements
WarLord
Post10-07-2005, 22:27    Subject: ABS Control Unit for Passat: Alternatives & Replacements Quote
Okay, on my Passat (year 1995), the contacts on the ABS control unit are corroded. Since the control unit is attached to the ABS module, it needs to be replaced (or I could replace the contacts, but where would I get those?).
Okay, I've done a little research and found that the Golf used an ABS module with a part number (3A0 907 379). Now I'm wondering where else that part was used, as I might be able to source parts from those vehicles.
Best regards, WarLord.
Translated on 28-10-2026, 7:35.
schraubernrw
Post04-09-2007, 14:52    Subject: ABS Control Unit for Passat: Alternatives & Replacements Quote
WarLord wrote:
Hey, on my Passat (year 1995), the contacts on the ABS control unit are corroded, and since the control unit is attached to the ABS block, it obviously needs to be replaced (or I could replace the contacts, but where can I get those?).
I've done some research and found that the Golf used an ABS module with a part number (3A0 907 379). Now I'm wondering where else this part was used, as I might be able to source parts from those vehicles.
Greetings, WarLord
Okay, I would start by checking out the junkyards, either in person or by phone.
Normally, you'd expect to find something like that there.
M.
Passat Var TDI, Baujahr 01/99, 81KW, MKB AFN
Translated on 28-10-2026, 7:37.
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat MKB AVB: Fuel Leak Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts LL Service: What event can trigger it? Diesel Engine Technology
No new posts Which Motor Oil Should I Use? Diesel Engine Technology
No new posts Oil Pump for JR Engine in VW Jetta Diesel Engine Technology
No new posts High Boost Issues: What Else Could It Be? Diesel Engine Technology
