10 Cent: A Different Take!
Marko
Post11-12-2002, 20:06    Subject: 10 Cent: A Different Take! Quote
Hi!
Could the "10-cent tuning" not be reversed, so that the engine control unit (ECU) reports too much fuel being used, thereby creating an "ECO" driving mode?
I'm looking to save on fuel costs.
Best regards: Marko
Lieber TDI statt lahme Ente!
-A6 4B2 2.5 TDI AYM-
Translated on 30-09-2026, 16:58.
Post11-12-2002, 21:26    Subject: 10 Cent: A Different Take! Quote
You can, for example, adjust the quantity control valve or simulate a higher quantity through engine control unit adaptation. However, the effect is the same as if you were simply using less fuel.
Having a faulty EGR valve and an injection timing that's 2 degrees too early already makes a significant difference.
I will not elaborate further on the topic of AGR and refer you to Ulf's expert article. The start of injection can be adjusted through the engine control unit adaptation.
The greatest fuel savings are likely to be achieved through adapting one's driving style.
Translated on 30-09-2026, 16:59.
eike
Post11-12-2002, 22:50    Subject: 10 Cent: A Different Take! Quote
I agree. With my G4 ALH 90PS engine, I once drove 100km on vacation using only 3.8 liters. But it was quite boring icon_smile.gif.
Here's a different question: If you modify the injection timing channel and advance the start of injection by 2°, surely that also has disadvantages, right? Does it only worsen the exhaust emissions, or does it affect other things as well (performance, noise, lifespan, etc.)?
Will the workshop notice something like that during a regular service? Or possibly the TÜV (German technical inspection agency) during the vehicle inspection (HU) and emissions test (AU)?
Eike.
Translated on 30-09-2026, 17:00.
Post11-12-2002, 22:54    Subject: 10 Cent: A Different Take! Quote
Hello Eike,
Disadvantages of starting injections too early, without claiming to be exhaustive:
- higher NOx emissions.
- Higher peak pressures during combustion.
- Louder running noise.
Translated on 30-09-2026, 17:02.
TDIBubi
Post12-12-2002, 13:41    Subject: Rainer: A Special Tribute Quote
'It seems like the box is extending the injection time.'
The 10-cent tuning advances the injection timing.
CAN YOU INSTALL A 'BOX' AND A '10 CENT-TUNING' SYSTEM TOGETHER????
Post12-12-2002, 13:50    Subject: Re: Special for Rainer Quote
TDIBubi wrote:
sagemal, the box extends the injection time.
CAN YOU INSTALL A "BOX" AND A "10 CENT-TUNING" SYSTEM TOGETHER?
"Of course, you can advance the injection timing using an RC circuit at the negative feedback (NBF) point. However, the question is, by how much does the injection timing change? While it's possible to find out, without a diagnostic tool, you'll only get rough estimates."
Of course, the maximum limit is determined by the mechanical pre-trigger of the ESP.
Without a thorough understanding of what you're doing and the appropriate measuring equipment, you shouldn't do anything. And your question indicates that you don't know what you're doing.
Please, no more "what if" questions. Instead, learn how your injection equipment works. All the information you need is already available here.
Translated on 30-09-2026, 17:04.
zzzZZ
Post12-12-2002, 13:52    Subject: Re: Special for Rainer Quote
Since when has 10-cent tuning been advancing the injection timing?
By tuning, you only increase the fuel injection amount, which is the principle behind power boxes.
Sure, you can combine those things, and if your TDI is still running, you'll have a fantastic steam-powered vehicle.
René K.
Translated on 30-09-2026, 17:06.
TDIBubi
Post12-12-2002, 14:09    Subject: Did I misread that? Quote
Okay, according to the '10-cent tuning' described here, see the last paragraph before the SDI section!!
'Earlier injection start.'
It describes how to advance the start of the injection process in parallel with cables 1 and 2.
or am I mistaken?
Now, a question specifically about this:
The power box is connected to all the cables (the entire connector before the ESP).
Why aren't there any fuel injectors yet that can both simulate a lack of fuel and also advance the fuel injection timing?
Is it possible to combine the described 10-cent tunings (multiple injection based on diesel temperature, simulating low boost pressure, and advanced injection timing)?
If you were to adjust everything 'within limits,' taking a little from each area, wouldn't that be a perfectly balanced tuning measure?
'Hello,'
And have a fun, crafty weekend!
Translated on 30-09-2026, 17:08.
zzzZZ
Post12-12-2002, 14:24    Subject: Misread? Did I misunderstand? Quote
So, according to the 10-cent tuning described here, see the last paragraph before SDI!!
or am I mistaken?
OK OK, as stated in the article, I concede. For me, these measures go beyond the usual '10 cent tuning,' it's more like 'extended 10 cent tuning.' Before the article was published, the forum had already discussed increasing the fuel injection volume, and that's all I remember.
René K.
Translated on 30-09-2026, 17:10.
TDIBubi
Post12-12-2002, 14:27    Subject: No problem! Quote
Yes, that's right!!
I'm just curious if and how I can combine the previous irrigation schedule with my new system.
It would definitely provide more power!
Translated on 30-09-2026, 17:11.
zzzZZ
Post12-12-2002, 14:37    Subject: 10 Cent: A Different Take! Quote
Okay, I haven't adjusted the injection timing yet. If I wanted to, I would only do it using VAG-Com or a similar tool through adaptation.
I slightly increased the boost pressure by replacing an SMD resistor in the engine control unit (ECU), which resulted in a lower measured pressure from the pressure sensor (in my ECU). This effectively eliminated the 'russeting' (likely referring to a specific sound or issue) when the tuning is activated.
But be aware: as described in the article, safe operation is not possible with every type of gas turbine.
René K.
Translated on 30-09-2026, 17:12.
TDIBubi
Post12-12-2002, 14:44    Subject: SEO: Understand! - Your Guide to Success Quote
Okay, of course I'll check my settings according to the information in the article beforehand!
If necessary, install a different pressure sensor, for example, one that measures up to 2.0 bar!
If you're going to work on the STG (Steuergerät - control unit), you have to open it, and in doing so, you'll destroy the VW seal, right?
Can I somehow integrate that into the cable using the charging pressure?
or should I check something directly on the pressure sensor?
Translated on 30-09-2026, 17:13.
Post12-12-2002, 14:56    Subject: 10 Cent: A Different Take! Quote
Just read through the old forum posts on those topics!
I don't want to have to repeat everything constantly just because someone is too lazy to check.
Rainer.
Translated on 30-09-2026, 17:14.
No new posts 10 cents, but different Diesel Engine Technology
No new posts TDI: A Different Approach Diesel Engine Technology
No new posts AFN LMM - A different kind of error Electrical Systems, Vehicle Electronics, Multimedia
No new posts Metering pump troubleshooting: A different approach? Diesel Engine Technology
