Engine Control Unit (ECU) Calibration for WFS
Go to page: 1, 2  Next
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
SpaceDragon
Post05-09-2007, 23:47    Subject: Engine Control Unit (ECU) Calibration for WFS Quote
Hi, ich habe mir ein Steuergerät beim Chip umlöten versaut. SElber is guilty.
Okay, I've now obtained a new control unit and want to synchronize it with the WFS. I have VAG-COM, but how do I do this? It's a Passat 3BG, year of manufacture: 2004, engine: AVF, control unit number: 038 906 019 KD.
The engine is currently starting briefly and then immediately returning to its normal state. The WFS indicator light on the instrument panel is flashing.
Can I use any TDI PD engine control unit (ECU) for my 130 hp TDI, as long as I replace the chip inside it?
Steve.
Translated on 07-08-2026, 3:17.
Ross-Tech-Support
Post05-09-2007, 23:50    Subject: Engine Control Unit (ECU) Calibration for WFS Quote
Are WFS pins present on both control units?
Control unit: Part number, old/new?
Translated on 07-08-2026, 3:18.
SpaceDragon
Post06-09-2007, 0:03    Subject: Engine Control Unit (ECU) Calibration for WFS Quote
Where can I get the immobilizer keys (pIns)? I don't have any.
Steuergerätenummer alt und neu sind momentan gleich. As stated above.
I would also like to build this here at location 038 906 019 KC.
Translated on 07-08-2026, 3:19.
atlantic
Karma: +1 / -1   Thank you, like it!
Post06-09-2007, 0:54    Subject: Engine Control Unit (ECU) Calibration for WFS Quote
You can either have your car's immobilizer programmed by VW, or you can try to read the login code yourself, but that's not easy for non-experts and also requires a lot of expensive hardware and software. Therefore, I would recommend having everything done professionally, otherwise you probably won't be able to get the login.
If you would like to choose the first option, there are specific tools available for that, such as those offered at vagdashcom.de.
Best regards, Max.
Translated on 07-08-2026, 3:20.
SpaceDragon
Post06-09-2007, 5:24    Subject: Engine Control Unit (ECU) Calibration for WFS Quote
If I can't do it with VAG-COM, then I have to get it done at a VW dealership. Does anyone know how much that costs?
Can I now use other engine control units (ECUs) that are also designed for the 1.9 TDI PD engine and then have them calibrated with a software update to work specifically with my engine?
Translated on 07-08-2026, 3:21.
Rudi
Post06-09-2007, 8:32    Subject: Engine Control Unit (ECU) Calibration for WFS Quote
Hi, I damaged a control unit by having its chips re-soldered.
It is quite difficult to damage an EDC15 unit icon_rolleyes.gif.
Can I now also use other engine control units (ECUs) that are also from the 1.9 TDI PD and then have them precisely adjusted for my engine with a software update?
Without modifications, definitely not. With some specific models (PDs), the STG hardware is incompatible – nothing will work in that case.
Otherwise, you need the appropriate tools (which are expensive) and the corresponding expertise.
(which certainly won't be distributed icon_wink.gif)
Rudi
Translated on 07-08-2026, 3:22.
SpaceDragon
Post06-09-2007, 15:43    Subject: Engine Control Unit (ECU) Calibration for WFS Quote
I don't know how many chips you've already re-soldered, but for me, after several attempts, it was the first time that a component which should have been securely attached to the circuit board came loose.
It seems like someone just had bad luck and wasn't necessarily doing a poor job.
But thank you for your help.
Here's the translation:
'One more question: Can I program (calibrate) the engine control unit with VAG-COM if I have the PIN? If so, how?'
Translated on 07-08-2026, 3:24.
Ross-Tech-Support
Post06-09-2007, 15:50    Subject: Engine Control Unit (ECU) Calibration for WFS Quote
SpaceDragon wrote:
One more question: Can I program (adapt) the engine control unit with VAG-COM if I have the PIN code? If so, how?
http://wiki.ross-tech.com/index.php/Immobilizer_III_ECU_Swapping
Post06-09-2007, 15:51    Subject: Engine Control Unit (ECU) Calibration for WFS Quote
SpaceDragon wrote:
I don't know how many chips you have already resoldered...
... Thousands...
"... but for me, after several attempts, it was the first time that a component which should have been securely attached to the circuit board came loose."
Heat damage.
The pads only detach when exposed to excessive or prolonged heat.
No, unfortunately, the work was done without proper qualifications.
But honestly, it sometimes happens to me that a pad comes loose, especially if you're too impatient. However, that's still no reason to give up on the electronics.
Translated on 07-08-2026, 3:26.
SpaceDragon
Post06-09-2007, 16:25    Subject: Engine Control Unit (ECU) Calibration for WFS Quote
I'm happy to listen to your suggestions or even give you a call. I'm open to any tips. But I have to admit that the pad already came loose when I removed the chip, and it was the very first pin, so it wasn't really hot. I would have suspected an air bubble instead.
But as I said, I would be very grateful for any help you can offer.
Translated on 07-08-2026, 3:27.
Post06-09-2007, 17:18    Subject: Engine Control Unit (ECU) Calibration for WFS Quote
SpaceDragon wrote:
... I would be very grateful for a tip.
Carefully detach the pad completely with the scalpel and solder a thin silver wire to the remaining trace. Then, connect the silver wire to the original pin.
Translated on 07-08-2026, 3:28.
SpaceDragon
Post06-09-2007, 17:22    Subject: Engine Control Unit (ECU) Calibration for WFS Quote
Okay, the pad is completely gone. Unfortunately, it's also very difficult to see where the traces lead or where I could solder the silver wire.
Rudi
Post06-09-2007, 17:25    Subject: Engine Control Unit (ECU) Calibration for WFS Quote
Which pin on the flash?
Translated on 07-08-2026, 3:29.
SpaceDragon
Post06-09-2007, 17:43    Subject: Engine Control Unit (ECU) Calibration for WFS Quote
The first two, specifically where the chip has its marking.
Rudi
Post06-09-2007, 17:55    Subject: Engine Control Unit (ECU) Calibration for WFS Quote
1: N.C.
2: RY/!BY (ready/!busy) Output from the flash memory that the microcontroller does not process.
If that's all there is, the machine should still be running.
Rudi
SpaceDragon
Post06-09-2007, 17:59    Subject: Engine Control Unit (ECU) Calibration for WFS Quote
N.C. = No contact???
Is the Ready/Busy status not being evaluated or something? So, are those two pins essentially irrelevant for now? Should the device still work even without them?
P.S. First of all, thank you very much for your answers.
Translated on 07-08-2026, 3:30.
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T5 Model 2014 Key Programming via VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N FSI engine control unit programming Gasoline Engine Technology
No new posts Golf 4 engine control unit programming On-Board Diagnostics (OBD)
No new posts Immobilizer: Engine Control Unit (ECU) Not Learning On-Board Diagnostics (OBD)
No new posts WFS Setup: How to Configure and Use On-Board Diagnostics (OBD)
