Gremlin Schrauber
Joined: 08/18/2005 Posts: 396 Karma: +92 / -0 Location: Grainet 2000 Audi A4 Avant  Premium Support
18-09-2007, 15:18 Subject: Question about transponders with exchange codes |
Hello everyone,
Problem:
I installed a remote control for the central locking system in my Audi A3 (year of manufacture 1998) – as mentioned before, it has a transponder with a rolling code. I had new interior key blanks made to fit the old flip-key design.
"They cannot be paired. According to the workshop, they can only be paired once (to a donor vehicle), so not to my system."
Is this statement correct?
Regards
Translated on 20-07-2026, 20:15.
Profile PM Garage |
mullemaus Guest
18-09-2007, 19:20 Subject: Question about transponders with exchange codes |
In 98, you have WFS II. WFS II transponders can be programmed onto other vehicles. For FFB systems, it depends on the control unit and the frequency.
Translated on 20-07-2026, 20:16.
Gremlin Schrauber
18-09-2007, 19:51 Subject: Question about transponders with exchange codes |
Hello Mulle,
I thought WFS2 was a fixed code, but I definitely have changeable code ("W" marked on the original key).
Then I wonder what's going wrong at the workshop, or is it a problem *because* the adjustment is being done online?
Regarding the FFB (presumably a product or feature), it's clear that it works well and is suitable.
Translated on 20-07-2026, 20:17.
Profile PM Garage |
mullemaus Guest
18-09-2007, 20:05 Subject: Question about transponders with exchange codes |
Hello Mulle,
I thought WFS2 was a fixed code? But I definitely have changeable code! (-Original key marked with 'W')
WFS I is fixed code, while WFS II uses variable code.
Then I wonder what they are doing wrong in the workshop, or is this a problem BECAUSE the adjustment is made online?
Normally not, but it should work.
Translated on 20-07-2026, 20:19.
Gremlin Schrauber
18-09-2007, 20:18 Subject: Question about transponders with exchange codes |
Sure, here's the translation:
"Well..."
Then I'll say thank you!
Thankfully, I didn't have to pay anything for the "failure"!
Translated on 20-07-2026, 20:20.
Profile PM Garage |
mullemaus Guest
18-09-2007, 21:16 Subject: Question about transponders with exchange codes |
Well,
Thankfully, I didn't have to pay anything for the 'failure'!
Regards.
I installed a remote control for the central locking system of a butcher's shop.
Please note: If the 'butcher' is a WFS III, then the transponders will not work; they are 'locked.'  WFS II units work in any other WFS II unit. Just for information, so we don't misunderstand each other.
Translated on 20-07-2026, 20:21.
Gremlin Schrauber
18-09-2007, 21:38 Subject: Question about transponders with exchange codes |
Of course, that's also a possibility...
I haven't been able to find any other part numbers for the A3 (folding key head with replaceable code transponder, 4D0837246B, used from 1997-2003).
The donor vehicle was an A3, a front-wheel drive model with 130 horsepower and S-Line trim, manufactured in 2002.
Translated on 20-07-2026, 20:22.
Profile PM Garage |
mullemaus Guest
18-09-2007, 23:09 Subject: Question about transponders with exchange codes |
Regards.
The 02 is definitely a WFS III  . Therefore, the transponder is locked and unusable.  Even the FFB (Front Front Bus) shouldn't fit on the old model. The only solution is a new transponder and a different radio controller.  You can see this with the FFB in the error memory. After the learning process, there should be an error message displayed. }
Translated on 20-07-2026, 20:24.
Gremlin Schrauber
19-09-2007, 6:47 Subject: Question about transponders with exchange codes |
Morning.
So, everything is clear now. I would just like to thank you for explaining it so thoroughly!
P.S.: Regarding the radio control units: They are compatible and interchangeable, with 2-button versions working with 3-button versions, and they can also be programmed. The only drawback is that the trunk release button doesn't function. Since I didn't receive a complete set (without the pump), I obtained a faulty unit from a local workshop – often, it's the old graphite pump that fails – and transplanted the electronics from my original unit into it.
Translated on 20-07-2026, 20:25.
Profile PM Garage |
