Mr.Richi Blaumann
23-09-2007, 1:47 Subject: Golf 2 Speedometer Removal: Guide & Instructions |
What's the easiest or fastest way to get it out?
What's even more important is how to deal with the driveshaft; I don't know how to get it off from the back.
Translated on 10-08-2026, 14:15.
Malte1408 Schrauber
Joined: 06/23/2005 Posts: 427 Karma: +12 / -0 Location: Hannover
23-09-2007, 10:46 Subject: Golf 2 Speedometer Removal: Guide & Instructions |
"Remove all the switches and the heating control panel. There are screws behind them in various places."
Remove all the screws and take off the control panel cover.
The gearbox has two screws that come loose, and then the gearbox is only held in place by the speedometer cable.
To get it out, I think I removed the panel under the steering wheel and fiddled around from underneath.
The connector is inserted and has clamping jaws that need to be squeezed together.
Translated on 10-08-2026, 14:16.
Mr.Richi Blaumann
23-09-2007, 14:35 Subject: Golf 2 Speedometer Removal: Guide & Instructions |
I once read something about a plastic part potentially falling off the tachometer shaft.
Translated on 10-08-2026, 14:17.
wutz Blaumann
Joined: 08/13/2004 Posts: 247 Karma: +11 / -1 Location: BRA 2006 Seat Leon Free account, no CAN development support
25-09-2007, 9:53 Subject: Golf 2 Speedometer Removal: Guide & Instructions |
"On my Golf 2 from 1988, no plastic part came out when I removed the speedometer cable. When you pull off the cable, don't bend it downwards, as it leads upwards to the speedometer; otherwise, nothing should fall out. You can either remove the cable from below or try to slide it past the speedometer on the side, although that's not easy and be careful not to scratch the plastic with your hands."
Translated on 10-08-2026, 14:18.
Profile PM Garage |
