NorthstarV8
25-07-2007, 16:17 Subject: VW AGR Tester Rate |
weiß jemand die Schritte bzw. Vorgehensweise bei dem VW Tester z.b. 5051 oder 5052 ? Is it the same here?
/viewtopic.php?t=3095
Thank you in advance.
Ross-Tech-Support Profi-Schrauber
25-07-2007, 16:35 Subject: VW AGR Tester Rate |
It is similar, depending on which base version is running on the VAS.
NorthstarV8
25-07-2007, 17:05 Subject: VW AGR Tester Rate |
But do the address codes match?
26-07-2007, 22:39 Subject: VW AGR Tester Rate |
Yes, only the function numbers can differ.
NorthstarV8
13-08-2007, 16:10 Subject: VW AGR Tester Rate |
My workshop can't figure out the VAG-COM manual. Does anyone know the steps regarding 5051 or 5052?
13-08-2007, 16:40 Subject: VW AGR Tester Rate |
Then you should look for a different workshop, that's basically elementary workshop knowledge...
NorthstarV8
13-08-2007, 16:50 Subject: VW AGR Tester Rate |
The problem is that the channels apparently don't fit.
Malte1408 Schrauber
Joined: 06/23/2005 Posts: 427 Karma: +12 / -0 Location: Hannover
13-08-2007, 16:53 Subject: VW AGR Tester Rate |
What kind of engine do you have, actually?
NorthstarV8
13-08-2007, 17:10 Subject: VW AGR Tester Rate |
I have a BLT motor.
Malte1408 Schrauber
14-08-2007, 0:05 Subject: VW AGR Tester Rate |
NorthstarV8 wrote: | | I have a BLT motor |
While I don't know it, it sounds like EDC16 = different adjustment channels and adaptation of air mass is no longer possible.
14-08-2007, 0:37 Subject: VW AGR Tester Rate |
The BLT should actually be an EDC15, similar to PD-TDI, but uses KWP-1281 as the diagnostic protocol, which the EDC16 does not support. Based on my experience, the adjustment channels and other components are as described in the above article and are known as such. Therefore, I recommend seeking a different workshop.
spajor
14-08-2007, 13:35 Subject: Problem with the workshop, I am familiar with. |
The mechanic had to ask his colleagues three times how to enter the login code, and then find the channel, and he was very proud that the adaptation had worked...
Well, at least the noise-making light is now off.
Ölfinger Blaumann
27-09-2007, 20:30 Subject: VW AGR Tester Rate |
Can someone now say whether the adjustment of the air mass (AGR rate) can also be done via channel 3 with the VAG 5051/B
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
27-09-2007, 20:39 Subject: VW AGR Tester Rate |
Ölfinger wrote: | Can someone now say whether adjusting the air mass (AGR rate) with the VAG 5051/B also takes place via channel 3  |
yes. This depends not on the device, but on the control unit. ...because it's actually in channel 3 for all EDC15s...
I had already emailed.
Hello, Rainer
Profile PM WWW Garage |
