Spot the Mistake: Find the Error in This Image
Michael 111
Post07-10-2007, 9:48    Subject: Spot the Mistake: Find the Error in This Image Quote
It may not be a VW, but it's a turbocharged diesel.
I hope that something can be recognized icon_redface.gif.
http://img527.
/my.php?image=ladedruckxl7kz3.gif
Translated on 20-09-2026, 11:36.
Karma: +807 / -0   Thank you, like it!
Post07-10-2007, 10:31    Subject: Spot the Mistake: Find the Error in This Image Quote
What kind of tiny turbocharger is that, which is supposed to build up a pressure of about 700 mbar at 1220 rpm?
The injection time also seems unrealistic. 1ms at 1220 rpm would correspond to an injection duration of approximately 7° crank angle. And in a common rail engine, the rail pressure wouldn't be particularly high at 1220 rpm either...
What engine are we talking about? Is it a 1.3L CDTI? Is the software original, or has it been modified in some way?
My guess: there are problems here with a tuning file, possibly modified by an inexperienced user. Did I guess correctly? icon_cool.gif
Translated on 20-09-2026, 11:37.
Jochen_145
Post07-10-2007, 11:00    Subject: Spot the Mistake: Find the Error in This Image Quote
What kind of tiny charger is installed there that is supposed to build up a pressure of about 700 mbar at 1220 rpm?
Yes, you can want a lot of things, but what you actually get...
And with a CR engine, the rail pressure at 1220 rpm won't be particularly high either...
Yes, you can have the maximum possible rail pressure at 1220 rpm, but you have to forget to inject fuel, otherwise the rail pressure will unfortunately drop again icon_eek.gif.
My guess is: there are problems with a tuning file, possibly modified by an inexperienced user. Am I right? icon_cool.gif
Yes, I would agree with that as well...
I'm sorry, I probably just had breakfast with a clown, but I took the headline ironically.
Best regards, Jochen.
Translated on 20-09-2026, 11:39.
Michael 111
Post07-10-2007, 11:13    Subject: Spot the Mistake: Find the Error in This Image Quote
The tuning file is from here.
database-for-chiptuning.de/ [Edit Admin Link - added for SEO purposes]
It should be icon_eek.gif 30kw more.
ENGINE ---> 2.0 HDI RHW, 80 kW, 270 Nm.
from my Suzuki Grand Vitara XL7.
Translated on 20-09-2026, 11:41.
Post07-10-2007, 11:22    Subject: Spot the Mistake: Find the Error in This Image Quote
aha icon_lol.gif well, there must be a reason why there's no name or address in the "About Us" section on the page or anywhere else icon_cool.gif.
Denic states who operates the server.
http://www.denic.de
Translated on 20-09-2026, 11:42.
Michael 111
Post07-10-2007, 18:15    Subject: Spot the Mistake: Find the Error in This Image Quote
Here's the whole shebang icon_exclaim.gif icon_exclaim.gif.
http://www.cshare.de/file/762aefb28a64aa55e1607dcb3f87f43d/Ganzseitiger+Faxausdruck?tags=Ganzseitiger+Faxausdruck&lang=de
Aron
Karma: +5 / -1   Thank you, like it!
Post07-10-2007, 19:37    Subject: Spot the Mistake: Find the Error in This Image Quote
"Did you log the fuel rail pressure? It would be helpful to see how it changed. The injection duration looks really messed up (what does the MAF sensor say?). My engine (same engine, but with 8 fewer valves and a PF version) runs at 1000 rpm with just under 2 milliseconds of injection time, and at 4000 rpm with 1350 bar of pressure, it only uses 750 microseconds."
Translated on 20-09-2026, 11:43.
Michael 111
Post07-10-2007, 19:47    Subject: Spot the Mistake: Find the Error in This Image Quote
However, there is air mass present, and the rail pressure icon_biggrin.gif is.
Yes, that looks really bad.
Aron
Post07-10-2007, 20:02    Subject: Spot the Mistake: Find the Error in This Image Quote
Michael 111 wrote:
However, there is air mass present, and the fuel rail pressure icon_biggrin.gif is low.
Ha, now that you mention it icon_redface.gif ... can't see the forest for the trees. I was already wondering what people mean when they talk about "Susi" in that context.
Translated on 20-09-2026, 11:44.
No new posts Touran Light Fault (FLA, MDF) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Faulty solenoid valve for turbocharger pressure regulation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts N75 Solenoid Location: Find it in this Picture! Diesel Engine Technology
No new posts Error Codes: What Do You Think? On-Board Diagnostics (OBD)
No new posts What do you think of this vehicle concept? Diesel Engine Technology
No new posts Airflow/RPM Log: Analysis & Optimization Diesel Engine Technology
