AFN Clutch Upgrade: Heavy Duty for Dual Mass Flywheel
Neno
Post02-02-2008, 14:05    Subject: AFN Clutch Upgrade: Heavy Duty for Dual Mass Flywheel Quote
Hello everyone!
I have a problem! I've been desperately searching for a reinforced clutch for my AFN engine for days. I currently have the original clutch installed, which has a diameter of 220mm. The only thing I've found so far is from Sachs, but it's 228mm in diameter, and as far as I know, that won't fit, right?
I'm actually going to be driving approximately 400 kilometers with the CYP transmission soon! Not with the AFN engine, but with the 1.8T 225 HP engine from the TT. As I mentioned, I currently have the AFN transmission with a dual-mass flywheel installed on that engine. I want to install a reinforced clutch because I plan to increase the power of the 1.8T in the future.
Many people have advised me to get a G60 with an upgraded clutch, but I'm not really sure about it! It also compromises the comfort a bit, which I don't want!
So, do you have any ideas about using a reinforced clutch with a dual-mass flywheel?
Okay, how about the dual-mass flywheels from the Golf 4 (110 HP TDI, 130 HP TDI, etc.)? Would those fit too? Don't they have a 228mm clutch?
Translated on 05-10-2026, 5:58.
Audi_A4_haza
Post04-02-2008, 19:17    Subject: AFN Clutch Upgrade: Heavy Duty for Dual Mass Flywheel Quote
The only thing that makes sense is to convert to an EMS system in combination with a Sachs racing sport clutch.
It's definitely not cheap! (The clutch alone costs around 520 euros!)
Translated on 05-10-2026, 5:59.
mullemaus
Post04-02-2008, 22:09    Subject: AFN Clutch Upgrade: Heavy Duty for Dual Mass Flywheel Quote
The only thing that makes sense is a conversion to EMS in combination with a Sachs racing sport clutch.
It's definitely not cheap! (The clutch alone costs about 520 euros!) icon_wink.gif
The entire kit, including 2 MSRs, costs just over €500. icon_lol.gif EMS was discussed and quickly rejected in the TDI. icon_wink.gif } (read)
Translated on 05-10-2026, 6:00.
Audi_A4_haza
Post04-02-2008, 23:04    Subject: AFN Clutch Upgrade: Heavy Duty for Dual Mass Flywheel Quote
Can you provide me with a source (preferably via private message)? What about the 1z model? Does Sachs offer anything more powerful? (under 520 euros icon_wink.gif)
Translated on 05-10-2026, 6:01.
majesty78
Post05-02-2008, 6:18    Subject: AFN Clutch Upgrade: Heavy Duty for Dual Mass Flywheel Quote
He's driving a 1.8 T, not a TDI!
In my opinion, it doesn't need a ZMS.
SPEC clutches are available up to 800 Nm, which should definitely be sufficient. However, Stage 2 or Stage 2+ is usually enough.
Best regards, Alex.
Translated on 05-10-2026, 6:02.
Audi_A4_haza
Post05-02-2008, 18:05    Subject: AFN Clutch Upgrade: Heavy Duty for Dual Mass Flywheel Quote
The entire kit, including 2 MSRs, costs just over €500. icon_lol.gif EMS was discussed and quickly rejected in the TDI. icon_wink.gif (read). icon_cool.gif
Have you found a source yet, or was that just hot air (on the forum)? }
Translated on 05-10-2026, 6:03.
3 Phasen Biber
Karma: +2 / -1   Thank you, like it!
2001 Volkswagen Golf
Post09-02-2008, 12:38    Subject: AFN Clutch Upgrade: Heavy Duty for Dual Mass Flywheel Quote
I think this topic can be closed now!
If you want to tune something, you have to invest money! Otherwise, it's either not possible or the result will be garbage.
ehemals G4 ASZ, jetzt G4 ARL
slg60
Post06-03-2008, 22:21    Subject: AFN Clutch Upgrade: Heavy Duty for Dual Mass Flywheel Quote
Why would someone install a dual-mass flywheel (ZMS) on a 1.8 T? A TDI driver would be happy not to need a ZMS, and if they installed one even though they didn't need it, that would be ridiculous! icon_confused.gif
Translated on 05-10-2026, 6:04.
No new posts A4 1.9 TDI: Engine Jerks Like Clutch Slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Noise / Clutch Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Clutch Squeal: A3 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Reinforced Clutch 1Z Diesel Engine Technology
This topic is locked, you cannot edit or reply. ALH Engine: Clutch Problems & Solutions Diesel Engine Technology
No new posts Noise in BMW X3 when pressing the clutch Diesel Engine Technology
No new posts Golf TDI: Upgrade Clutch for More Power Diesel Engine Technology
