A complete scan includes addresses and any existing errors. What you posted are only integrated control units. This is only of marginal interest and helps very little with troubleshooting and narrowing down the problem.
Here's an example of a scan with error messages, etc.
Tuesday, September 25, 2007, 1:56:33:43675
VAG-COM Version: DRV 704.1
Data as of: 20070905.
Vehicle type: 8E - Audi A4 B6/B7.
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
Vehicle Identification Number (VIN): WAUZZZ8Exxxxxxxxx
Mileage: 29280 km / 18193 miles
'Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein.'
Address 01: Engine, Label file: DRV\03G-906-016-BLB.LBL
Part number SW: 03G 906 016 GN, HW: 028 101 211 3.
Component: R4 2.0L EDC 0000SG 7002
Encoding: 0000072
Workshop #: WSC 00000
No errors found.
Readiness: 0 0 1 1 1
Address 03: Brakes
Label file: 8E0-910-517.LBL
Part number SW: 8E0 910 517 B, HW: 8E0 614 517 AT.
Component: ESP8 front panel, part number H04 0180.
Encoding: 0004401
Workshop #: WSC 06325
'One error found:'
01317 - Control unit in the instrument panel carrier (J285)
008 - implausible signal.
Environmental conditions:
Error Status: 01101000
Error Priority: 3
Error Frequency: 3
Lost Count: 40
Time: 0.
Hex Value: 0x0000
Hex Value: 0x0222
Hex Value: 0x00FF
Hex Value: 0xFF97
Hex Value: 0x00FF
Address 08: Heating/Climate. Label file: DRV\8E0-820-043.LBL.
Part number: 8E0 820 043 AK
Part: A4 Climate Control Unit 2728
Encoding: 00000
'One error found:'
01206 - Signal for ignition deactivation duration.
27-00 - implausible signal.
Address 09: Body Control Module
Label file: DRV\8E0-907-279-8EC.LBL
Part number: 8E0 907 279 L
Component: Internal load module, ECE 0304.
Encoding: 11001
Workshop #: WSC 65536
No errors found.
Address 15: Airbag
Label file: DRV\8E0-959-655-94.LBL
Part number SW: 8E0 959 655 G, HW: 8E0 959 655 G.
Part: Airbag 9.41 H10 3230
Encoding: 0033622
No errors found.
Address 16: Steering wheel
Label file: DRV\8E0-953-549.LBL
Part number: 8E0 953 549 S
Component: Steering column module 0611.
Encoding: 01012
3 errors found:
49-10 - No communication - Intermittent.
00474 - Control unit for immobilizer system.
01794 - Control unit with incorrect vehicle identification number.
35-00 - -
Address 17: Combination instrument
Label file: DRV\8E0-920-9xx-8E2.LBL
Part number: 8E0 920 900 K
Component: COMBINATION INSTRUMENT + SPEEDOMETER. RB4 D36.
Encoding: 03003
Workshop #: WSC 01725
WAUZZZ8Exxxxxxxxxx AUZxxxxxxxxxxx
2 errors found:
00438 - Fuel level sensor (G169).
30-00 - Disconnection / Short circuit after positive terminal.
01177 - Engine Control Unit.
65-10 - unauthorized - occasional.
Address 46: Comfort System
Label file: DRV\8E0-959-433-MIN.LBL
Part number: 8E0 959 433 BG
Component: Comfort Device T85, 2431.
Encoding: 07024
Part number: 8E1959801B
Component: Törsteuer.FS BRM 0205
Part number: 8E1959802B
Component: Törsteuer.BF BRM 0205
No errors found.
Address 56: Radio
Label file: DRV\8E0-035-1xx-56.LBL
Part number: 8E0 035 186 D
Part number: concert II GRO 0004.
Encoding: 01001
No errors found.
Address 76: Parking Assist
Label file: 8E0-919-283-8EC.LBL
Part number SW: 8E0 919 283 B, HW: 8E0 919 283 B.
Part: Parking assist system, 4-channel, H06 0020.
Encoding: 0000114
Workshop #: WSC 131071
No errors found.
'End'
