Crankshaft Position Sensor (G28) & Starting Problems
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post21-09-2007, 15:11    Subject: Crankshaft Position Sensor (G28) & Starting Problems Quote
My Audi A3 TDI AGR, manufactured in March 1997, won't start anymore.
Fuel is leaking from the injector lines, but not from the injectors themselves.
The error memory contained only one error code.
00513 Sensor for motor speed, g28.
Implausible signal detected sporadically.
/my.php?image=foto344ap5.jpg" target="_blank" class="postlink" rel="nofollow">icon_smile_thumb_up.gif" color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusätzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema für andere Leser nutzlos!
/img219/2142/foto344ap5.th.jpg" class="responsive" alt="http://img219.
/img219/2142/foto344ap5.th.jpg" onLoad="imgResize(this);" onMouseOver="imgCursor(this);" onClick="imgOpenResized(this);">
It would be plausible that this is the cause.
What surprises me is the fact that the tachometer is working perfectly fine.
The engine speed, as read with VAG-Com, also shows no deviations. The starter motor speed is around 300 RPM.
I'm really at my wit's end icon_cry.gif.
I disassembled and reassembled the ESP (Electrical Submersible Pump). All relevant components, such as the impeller and pump pistons, were measured and show no signs of wear.
Translated on 27-07-2026, 21:47.
Malte1408
Karma: +12 / -0   Thank you, like it!
Post21-09-2007, 18:53    Subject: Crankshaft Position Sensor (G28) & Starting Problems Quote
Okay, check the MWB 1 module during startup to see if it's activating the pump. If it is, then the problem is likely mechanical in nature.
Timing? Also, even when playing the organ in the MWB 5, check what the NHG is reporting about the injection start time.
Translated on 27-07-2026, 21:49.
Jochen_145
Post21-09-2007, 20:11    Subject: Engine Speed Sensor (G28) & Starting Problems? Quote
Could it be that the pump isn't generating enough pressure to open the first stage of the nozzles?
If VAG-Com displays a speed value, then the G28 sensor is also working.
Best regards, Jochen.
Translated on 27-07-2026, 21:50.
Mike3BG
Post22-09-2007, 8:55    Subject: Crankshaft Position Sensor (G28) & Starting Problems Quote
Hello!
The same applies to my Passat with the AVF engine. I've already replaced several parts, as mentioned in another thread, but nothing has helped so far! I'm still searching for a solution.
Here's a question for you: When your car cranks, does it sound normal like when it's out of fuel, or is it accompanied by clicking sounds? Does it make a sputtering noise like an old tractor? Mine makes that sputtering noise when starting, but it still doesn't start. After a while, though, it eventually starts and runs normally. The error code in the diagnostic memory is exactly the same as yours, even though it's definitely NOT the G28 sensor! I replaced that one first!
Let me know when you've made more progress.
Greetings.
Translated on 27-07-2026, 21:52.
Tagessuppe
Post22-09-2007, 16:41    Subject: Crankshaft Position Sensor (G28) & Starting Problems Quote
Here are the things I tried today:
Duesen geprueft > Zwischen 170 und 180 Bar. Spray pattern 1A.
"The measuring device is connected to the fuel injection lines and shows a reading of over 6 bar. This likely indicates that the pressure being measured is just the internal pressure of the pump."
I have reassembled and disassembled the ESP to see if anything went wrong during assembly. It seems that everything was assembled correctly. There are no broken pistons. icon_wink.gif
Something peculiar caught my attention. Specifically, I inserted a spacer block into the distribution head to simulate a pump cycle. I blocked the check valves to see if pressure would build up. As a result, some pressure did build up.
But, and this was strange, it gurgled out from the opening below the left pressure spring mount.
/my.php?image=foto391vc9.jpg" target="_blank" class="postlink" rel="nofollow">icon_smile_thumb_up.gif" color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusätzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema für andere Leser nutzlos!
/img160/4765/foto391vc9.th.jpg" class="responsive" alt="http://img160.
/img160/4765/foto391vc9.th.jpg" onLoad="imgResize(this);" onMouseOver="imgCursor(this);" onClick="imgOpenResized(this);">
The tiny black hole is located at the 8 o'clock position.
I added some diesel in reverse order, and it accumulated in the center of the high-pressure component.
What do you think? Am I correct in my theory that if the pump sucks in so much air that it causes pump failures, this air explodes during the compression stroke of the injection piston? And before the injection piston opens the bore to the fuel lines?! Because normally, a pressure greater than 170-180 bar would then escape through the ESD (Excessive Shut-off Device), if the bore opening were open.
Could it be that repeated explosions created a pathway to the small hole, allowing pressure to escape?
What is the purpose of this opening?
I couldn't find it anywhere in the Bosch book "Camshaft-controlled diesel distributor injection pumps."
@Mike3GB: No. It's just playing without any multiplexing.
I sent you the information about the cause of the error in my colleague's 130 hp common rail diesel engine yesterday.
The initial symptoms were exactly the same. It cranks, sputters as if it's trying to start, keeps cranking, and then starts normally as if nothing happened.
As described, it was the light switch that was causing problems with the onboard electronics.
It mainly happened to him when the device was warm, and never when it was cold.
Translated on 27-07-2026, 21:55.
Malte1408
Post22-09-2007, 20:10    Subject: Crankshaft Position Sensor (G28) & Starting Problems Quote
What do you think? Am I correct in my theory that if the pump sucks in air, so much that it causes pump failures, this air explodes during the compression stroke of the injection piston? And before the injection piston opens the bore to the fuel lines?! Because normally, a pressure greater than 170-180 bar would then escape through the ESD (Excessive Shut-off Device), if the bore opening were open.
Could it be that repeated explosions have created a path to the aforementioned small hole, through which pressure can escape?
"Explosion? More likely an implosion; there could be cavitation damage, but something like that wouldn't just tear through the entire high-pressure section..."
"But, just a quick question on the side: If I remove the ESD (Electronic Stability Device) and possibly also the pressure relief valves, wouldn't the pump still circulate fluid even with zero flow, simply due to the internal pressure within the pump?"
Does the high-pressure chamber still fill with material even when there is no feed rate, as long as the ELAB (presumably a piece of equipment) is open?
So, I'm not yet convinced that this pump was activated during the organ playing, and maybe the problem lies there instead.
Translated on 27-07-2026, 21:59.
Tagessuppe
Post22-09-2007, 20:39    Subject: Crankshaft Position Sensor (G28) & Starting Problems Quote
That's not likely. But perhaps the pressure damaged a seal or connection.
Okay. That's why I also thought that the 6 bar probably corresponds to the internal pressure.
Okay. I think I can mark the ELAB as complete.
Malte1408 wrote:
So, I'm not yet convinced that this pump was activated while the organ was playing, and maybe the problem lies there.
I don't know what to believe anymore. I've tried so much already.
The magnetic interlocking system appears to be functioning correctly after all the tests.
I believe that my problems might be related to the air intake system.
Translated on 27-07-2026, 22:02.
Malte1408
Post22-09-2007, 21:02    Subject: Crankshaft Position Sensor (G28) & Starting Problems Quote
I mean that the problem might not be with the pump itself; it could be perfectly fine, but if it's not being activated, it won't inject anything.
The G28 error doesn't just appear randomly. Diagnostic tools like DZM and VAG-COM are slow, so you might not notice if a signal is occasionally missing. However, the engine control unit (ECU) pays very close attention to these signals.
Even if the sensor is working correctly, there might still be damage to the wiring or its shielding. Or perhaps the sending wheel itself is faulty. (Ultimately, an oscilloscope might be necessary to diagnose the problem.)
Confirming whether the engine control unit (ECU) *wants* to start the engine would have shown a code of either P0341 or P0345 if it was cranking.
...Is it possible to delete the error?
Translated on 27-07-2026, 22:04.
Tagessuppe
Post23-09-2007, 12:19    Subject: Crankshaft Position Sensor (G28) & Starting Problems Quote
Yes, the error could be deleted without any problems.
And if you used starter fluid spray (yes, I know you're not supposed to),
It started up, but with reduced power in the lower range.
Finally, it started by simply pressing the accelerator and gently lowering the engine speed to idle with the pedal.
I read in another thread that the NHG (presumably a specific device or system) takes over the function of the G28 if the latter fails. And the NHG is not showing any error messages.
Translated on 27-07-2026, 22:07.
Malte1408
Post23-09-2007, 13:06    Subject: Crankshaft Position Sensor (G28) & Starting Problems Quote
I read in another thread that the NHG takes over the function of G28 if it fails.
This comes from the SSP (Specific System Program), which allows the NHG (Natural Gas Engine) to use the G28 as an alternative speed signal in case of a failure. In this scenario, the engine continues to run, and only the SB (Selective Catalytic Reduction) system is then controlled.
My EGR valve doesn't do that. It shuts off when you disconnect the G28 sensor, and it won't start again after that.
I can imagine that this function is only activated during driving (speed > 0 km/h) for safety reasons and then deactivates when the vehicle is stationary.
So, it started up, but with reduced power in the lower range.
Finally, it would start by simply giving it some gas and gently lowering the engine speed to idle with the accelerator pedal.
Hmm, that sounds more like the pump is no longer able to provide enough fuel. With the starting spray, you essentially bypassed the "lack of influence" on the amount of fuel being delivered during startup.
Then, you might have been able to use the pedal to bring the control system to its maximum setting, at which point the pump would inject enough fuel for the engine to run.
I can also imagine such behavior if, for example, the speed signal is too high. This could happen quickly if some kind of interference is counted as a pulse due to defects in the shielding. }
Have you ever encountered the error message "quantity setting device difference"?
Then either the pump is broken and not actually pumping anything, or the speed signal is distorted and possibly too high.
As I mentioned, the data for MWB 1, including injection quantity, speed, and pump voltage, would be highly valuable for these analyses.
Translated on 27-07-2026, 22:12.
Tagessuppe
Post25-09-2007, 16:23    Subject: Crankshaft Position Sensor (G28) & Starting Problems Quote
Thank you very much, Malte, for your tireless help icon_smile.gif.
At least one person is thinking about it.
So, I'm now about 99% sure that the distributor head has a defect.
I have already ordered a distributor head with a 11mm size.
Why not just get a new pump right away? Because the old one has served me well for 282,000 km, and I don't want to have to re-calibrate the engine control unit (ECU).
I have never encountered the "MSW rule difference" error.
Only the nozzle clogging error after the air.
My theory suggesting a faulty cylinder head: The engine is misfiring despite the chip tuning. If the G28 sensor were malfunctioning, it would be able to convert the data from the chip exactly, but within a different RPM range. However, if the fuel injector delivers 20-30% less fuel, while the boost pressure is very high due to the chip tuning, this scenario becomes plausible.
I also believe the error is related to the 600 km driven with air in the system, as it occurred immediately afterward. It could be due to an explosion, cavitation, or simply considering the mileage of the component.
Furthermore, the symptoms would be compensated for by the engine speed if there were a problem with the high-pressure component. When starting, the fuel simply has more time to bypass the injection piston.
Then, with the engine running smoothly, the target exhaust gas oxygen (O2) level is reached very late.
What still surprises me is the function of the small hole on the HD part.
Does anyone know what this is for?
Okay, so the HD part is arriving next week.
If that doesn't help, then a new pump will be installed.
I can now assemble and disassemble things with my eyes closed icon_wink.gif.
Translated on 27-07-2026, 22:20.
Malte1408
Post25-09-2007, 17:27    Subject: Crankshaft Position Sensor (G28) & Starting Problems Quote
Okay, based on the symptoms, it's not unlikely that at least the high-pressure generation of the pump is malfunctioning.
What I can't seem to get rid of is the G28 error. This error isn't being triggered randomly by the control unit.
The G28 is one of the most important sensors in the EDC system, alongside the G149.
The problem is that the engine speed input to the control unit has a very high sampling rate (the script for the EDC mentions 330 µs).
At idle speed (900 RPM) and with four reference marks, this results in a signal of only 60 Hz. However, the control unit is fast enough to detect brief deviations beyond the possible range between two reference marks, especially if there are 100 "spans" on the encoder disc or if something interferes with the signal line.
"The DZM and VAG-COM would have no chance at all to react. (With the DZM, if it were possible, this would certainly be deliberately prevented, perhaps even before the engine control unit outputs the RPM data)."
The switchgear is likely to react quickly in such a situation.
And if it occasionally jerks back towards zero power after half a rotation because the MSG is applying a speed of 5000 RPM for 5ms, then I can easily imagine that the motor won't start up anymore.
VW itself has commented on the error in the repair manual:
00513 Sensor for engine speed - G28, implausible signal.
Possible cause of error:
- Bent or loose feeder disc.
- G28 error.
- Interruption of the shielding conductor.
Possible effects:
- poor starting behavior
- uneven engine running, misfires
- increased idle speed
- Warning light is on.
reduced performance
- Tachometer not displaying.
Translated on 27-07-2026, 22:29.
Tagessuppe
Post16-10-2007, 21:23    Subject: Crankshaft Position Sensor (G28) & Starting Problems Quote
Okay everyone. I found some errors icon_biggrin.gif.
I'm somehow surprised by how much my theory aligns with the explosions in the high-pressure section.
was was accurate.
After waiting for 3 weeks for the new high-pressure part to arrive, I started to disassemble the large three-sided screw on the pump head. As I held the screw in my hands...
I immediately noticed that something wasn't quite right.
But see for yourselves...
/my.php?image=foto413es5.jpg" target="_blank" class="postlink" rel="nofollow">icon_smile_thumb_up.gif" color="red">Bitte keine Links zu externen Dateihostern! a) nerven die zusätzlich notwendigen Klicks, b) Wartezeit, Werbebanner/Werbepopups und notwendige Registrierungen, c) ist nach einiger Zeit die Datei weg und das Thema für andere Leser nutzlos!
/img145/4349/foto413es5.th.jpg" class="responsive" alt="http://img145.
/img145/4349/foto413es5.th.jpg" onLoad="imgResize(this);" onMouseOver="imgCursor(this);" onClick="imgOpenResized(this);">
At 4 hours, the material had been blasted away to a depth of 3 mm.
The material erosion is definitely not attributable to cavitation.
The fine cracks at the clamping edge were caused by tightening the screws. The excessive pressure increase likely caused this material to be blasted away.
You can see these cracks at 6 o'clock. I was able to remove the material with my fingernail in that area.
In this process, the fuel escaped into the hollow ring between the triangular screw and the high-density part, and then leaked back out through the hole that I mentioned earlier in a previous post.
As far as I could tell, the HD part seems to be undamaged. I think I'll reassemble it like this with a new triangular screw. Does anyone know the torque specification for that?
It's surprising that the car was still running at the end icon_confused.gif.
I'll go to the Bosch service center tomorrow and get the triangular screw.
Translated on 27-07-2026, 22:38.
Tagessuppe
Post17-10-2007, 11:45    Subject: Crankshaft Position Sensor (G28) & Starting Problems Quote
Okay, and now I have a pressing question for someone who is knowledgeable about this.
I would really appreciate it if you could respond to me.
Wenn ich den Motor auf OT stelle (mit Nockenwellenlineal), auf welcher Position befindet sich dann die Nut der ESP-Welle: Oben? Unten? Different?
Thank you!
Translated on 27-07-2026, 22:42.
No new posts P0321 Error: Faulty Crankshaft Sensor (VAG) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starting problem 1Z Diesel Engine Technology
No new posts Touran Crankshaft Position Sensor - Faulty Signal Diesel Engine Technology
No new posts TDI STG Questions: V6 Engine Problems On-Board Diagnostics (OBD)
No new posts Non-TDI Questions: Everything You Need to Know Diesel Engine Technology
