How to check the GRA function?
ckone
Post22-12-2002, 23:59    Subject: How to check the GRA function? Quote
Hi!
I have a question for you. How can I use VAG-COM to check if the GRA function is present in my Polo? The engine is an AXR! What code can I use to activate it?
Sure, here's the translation:
'Thank you in advance.'
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post23-12-2002, 12:26    Subject: How to check the GRA function? Quote
Hi!
I hope I'm not giving you any incorrect information about your engine, but in my case, I can see how the cruise control is functioning in the measurement blocks, specifically group 6, field 4 icon_smile.gif.
0 = Cruise control off; 1 = Cruise control on; 255 = No cruise control coded.
The encoding process is likely to proceed as follows:
01 for engine control unit.
11 for login procedure.
Login code: 11463
That's it.
Deactivation code GRA: 16167
Good luck and have fun!
brezelmann01
No new posts Check TDI injectors with VCDS (Common Rail) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Needle Valve Actuator: Construction & Functionality Technical Articles
No new posts T5 Brake Fluid MIL: No Function Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AGR Valve: Check Function & Repair Diesel Engine Technology
No new posts Check cooler fan function? Diesel Engine Technology
No new posts OBD Connector: Test Functionality & Troubleshooting On-Board Diagnostics (OBD)
No new posts AGR Function Test: High Differential Pressure? Diesel Engine Technology
