Defective Rear Window Defroster: Causes & Fixes
Marco
Post21-12-2002, 20:39    Subject: Defective Rear Window Defroster: Causes & Fixes Quote
Hello forum,
The heating element in the rear window of my G4 is defective.
Are there any repair kits available for purchase?
Is there a way to repair this without damaging the rest of the rear window defroster?
Marco
Translated on 30-07-2026, 2:31.
Post21-12-2002, 20:47    Subject: Defective Rear Window Defroster: Causes & Fixes Quote
Hello Marco,
You should be able to find silver conductive paint at an electronics store or at Conrad.
This is a bottle similar to nail polish, and it must be shaken well before use.
You shouldn't paint the entire heating element, but only cover the break in the wire (use a magnifying glass or multimeter to locate it).
Then wait until the paint is completely dry, and everything will be fine.
Translated on 30-07-2026, 2:32.
Marco
Post22-12-2002, 11:20    Subject: Defective Rear Window Defroster: Causes & Fixes Quote
Hello Rainer,
I tried it out last night, and after a while...
The exercise worked. I carefully covered the damaged area of the heating element with tape and applied the silver conductive paint using a syringe.
applied in several layers. The whole thing was done with a brush.
it doesn't work at all because I only end up reapplying the silver conductive paint with it.
wiped away. Do I need to apply a clear coat now?
Will the repaired area survive if you clean the rear window with glass cleaner?
Marc
Translated on 30-07-2026, 2:34.
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts C4 AEL Coolant Temp Display Malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Parking Assist Fault: Audi A6 (4B) Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Heated Rear Window Interferes with Car Radio Diesel Engine Technology
No new posts RCD500 CD Changer: Installation & Guide Transmission, Chassis, Body & Interior
No new posts What is this part called? Diesel Engine Technology
No new posts 2.5 TDI: Unknown part of the oil pump chain Diesel Engine Technology
