Glow Plug Light: Meaning & Troubleshooting
Hesse
Post27-11-2007, 13:57    Subject: Glow Plug Light: Meaning & Troubleshooting Quote
I have this error in the control unit.
The vehicle is a 1.9 TDI model manufactured in 1996.
Is the fault directly within the AI system, meaning a problem on the tachograph circuit board, or could it be something else that's causing the error message?
By the way, the yellow light always flickers slightly.
Translated on 03-09-2026, 14:03.
Post27-11-2007, 14:27    Subject: Glow Plug Light: Meaning & Troubleshooting Quote
You have everything you need.
- A descriptive error code that clearly indicates what is broken.
- and a real-world situation that corresponds to the code.
Okay, I'll check the bacon and measure the voltage on the "Wendel" wires.
JA, ich weiss, das is ne Schei.. Work.
Translated on 03-09-2026, 14:04.
Hesse
Post27-11-2007, 14:29    Subject: Glow Plug Light: Meaning & Troubleshooting Quote
dieselmartin wrote:
You have everything you need:
Okay... there might have been something in the engine compartment that was causing the light to flicker, and that's a known weak point.
But if it all comes down to AI, I'll probably have to test that out.
Thank you!
Translated on 03-09-2026, 14:05.
Post27-11-2007, 14:31    Subject: Glow Plug Light: Meaning & Troubleshooting Quote
If you think you've found it:
In the "Output tests" of the Motor Control Unit (STG), there is a point that turns the lamp on and off. Therefore, you don't need to pre-glow until the battery is empty icon_smile.gif.
Translated on 03-09-2026, 14:06.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
