Boost Gauge Installation: What Distance?
Einer wie keiner
Post09-10-2003, 9:59    Subject: Boost Gauge Installation: What Distance? Quote
Hello everyone,
I just bought a boost gauge icon_biggrin.gif.
'Now I'm not exactly sure where I should connect them.'
Alternatively, should it be kept at a certain distance from the incoming boost pressure hose?
(For whatever reason)
I took a picture of it once.
www.planet-schulze.de/Ladedruck.jpg
I'm looking forward to responses icon_smile.gif.
Translated on 21-10-2026, 6:39.
Karma: +807 / -0   Thank you, like it!
Post09-10-2003, 10:21    Subject: Boost Gauge Installation: What Distance? Quote
Insert the T-piece and it's done icon_smile.gif.
Post09-10-2003, 15:37    Subject: Boost Gauge Installation: What Distance? Quote
Just click on my signature; you'll find the (in my opinion) most important tips there.
I don't understand your question about the distance (which point on which hose are you referring to?), but it might be answered in the LDA technical article.
Translated on 21-10-2026, 6:40.
LZ
Post09-10-2003, 16:07    Subject: Boost Gauge Installation: What Distance? Quote
@One of a kind.
"What kind of instrument did you buy? I've been looking for a manual pointer instrument that's smaller than the 52mm panel-mount version for a while. Not even Festo has anything remotely similar. Maybe someone knows a source?"
Thank you, Robert.
Translated on 21-10-2026, 6:41.
Einer wie keiner
Post09-10-2003, 19:42    Subject: Boost Gauge Installation: What Distance? Quote
@ulf
I have read your 'signature,' and it is truly very interesting icon_biggrin.gif.
@LZ
I bought this on eBay; it's from the manufacturer Turbo Motors. It's a 52mm one icon_rolleyes.gif. I also looked for a smaller one, but I couldn't find it.
There was also a T-piece with a constriction included, which is supposed to prevent the indicator from flickering. You should read Ulf's 'essential guide'; it's really well described there icon_biggrin.gif.
My current problem is finding a suitable location for it. I had previously removed the trim from the A-pillar, and I was planning to install it there, but the amount of work involved was too high (and the visibility wouldn't be as good). Unfortunately, there's also no more space where the (old) radio used to be, as it's a 16:9 screen. That would have been a great place to install it. Well, I'll have to keep looking.
Have a good evening.
Andy
Translated on 21-10-2026, 6:42.
kossmann
2016 Audi Q3
Post10-12-2007, 16:48    Subject: Boost Gauge Installation: What Distance? Quote
Where can one actually get a 4-meter boost pressure hose? I can't find one (boost pressure hose, pressure hose, rubber hose) at the auction house, and at the dealership, you'll end up being very poor, as they probably want over 15 euros per meter. Rainer also doesn't have one in his shop icon_confused.gif.
Translated on 21-10-2026, 6:44.
Aron
Karma: +5 / -1   Thank you, like it!
Post10-12-2007, 17:20    Subject: Boost Gauge Installation: What Distance? Quote
Tino Kossmann wrote:
Where can one actually get a 4-meter charge air hose? I can't find one (charge air hose, pressure hose, rubber hose) at the auction house, and at the dealership, you'll end up being very poor, as they want about 15 euros per meter. Rainer also doesn't have one in his shop icon_confused.gif
Fuel hose, available from a reputable parts dealer, for example.
A thin and robust option, for example, is a fuel hose for auxiliary heaters (with an outer diameter of 5mm and an inner diameter of 1mm). Placing a fuel filter before it will also significantly reduce needle fluctuations.
Translated on 21-10-2026, 6:45.
Post10-12-2007, 19:18    Subject: Boost Gauge Installation: What Distance? Quote
Where can one actually get a 4-meter charging pressure hose?
"Nowadays, I use regular, clear tubing that's commonly sold for home, garden, and aquarium use. It's been working perfectly in our TDIs for several years without any problems."
Translated on 21-10-2026, 6:46.
cksIT
Post11-12-2007, 12:45    Subject: Boost Gauge Installation: What Distance? Quote
I can get the same hose from my supplier for 1€ per meter... there's nothing to say about that.
It's best to just ask around.
christians
Post12-12-2007, 12:36    Subject: Boost Gauge Installation: What Distance? Quote
I now use completely ordinary clear tubing for household, garden, and aquarium use, and it has lasted for several years without any problems in our TDIs.
Me too.
Gruß Christian
Translated on 21-10-2026, 6:47.
Jochen_145
Post12-12-2007, 20:36    Subject: Boost Gauge Installation: What Distance? Quote
I bought vacuum hose from the parts dealer in bulk.
It didn't cost much more, but it's more stable, so the hose is less likely to kink when you have to route it through the injection molding machine.
Best regards, Jochen.
Translated on 21-10-2026, 6:48.
kossmann
2016 Audi Q3
Post13-12-2007, 7:42    Subject: Boost Gauge Installation: What Distance? Quote
Jochen_145 wrote:
I bought vacuum hose from the parts dealer in bulk, by the meter.
It didn't cost much more, but it's more stable, so the hose is less likely to kink when you have to run it through the injection wall.
"Could you please provide the part number and the price? My local dealer quoted me around 9 euros per meter recently, which is what's listed in the catalog. However, I thought that price was for 5 meters, which I would have been willing to pay."
No new posts Digital boost pressure indicator Troubleshooting & Guides
No new posts Boost Gauge: Essential for Every TDI Engine Troubleshooting & Guides
No new posts Is the distance between the roof and the supporting beams... Transmission, Chassis, Body & Interior
No new posts ESP Installation/Removal for AEL Vehicles Diesel Engine Technology
No new posts GRA Installation: Wiring Diagram & Guide Diesel Engine Technology
No new posts Auxiliary Heater Installation: Guide & Tips Transmission, Chassis, Body & Interior
