Bordnetz Golf VII
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Hifigarage
Post15-12-2016, 15:58    Subject: Bordnetz Golf VII Quote
I'm new to this forum and I have a question right away. I have a Golf VII that I've converted from standard headlights to xenon, and now I want to code the car's electrical system. However, I'm getting the message "no documentation available". Can someone help me? Which bits do I need to code? Thanks.
Post15-12-2016, 17:14    Subject: Bordnetz Golf VII Quote
no. Where is your car scan, and where can I see what's installed and how it's been coded?
Best regards, Rainer
Hifigarage
Post15-12-2016, 18:05    Subject: Bordnetz Golf VII Quote
Oh, sorry, I'll be sure to pay attention next time. Here is the car scan.
vcds golf VII.txt
 Bordnetz Golf VII
Bordnetz Golf VII
 File name:  vcds golf VII.txt
 File size:  33.94 KB
 Downloaded:  1374 times
Hifigarage
Post15-12-2016, 18:10    Subject: Bordnetz Golf VII Quote
Please disregard any errors, the entire vehicle is disassembled. I would also like to have the multifunction steering wheel coded, and I would be grateful for any assistance.
Post15-12-2016, 22:24    Subject: Bordnetz Golf VII Quote
Unfortunately, there is no label file available for your onboard control unit yet... please wait. I will pass on the information.
Hifigarage
Post16-12-2016, 9:34    Subject: Bordnetz Golf VII Quote
ok, danke. How long could it take approximately?
Best regards, Roy
Post16-12-2016, 12:05    Subject: Re: Golf VII Wiring Quote
Best regards, Roy
No idea icon_smile.gif Have you already searched online for auto-scans with identical control units and Xenon headlights?
In such cases, please do not blindly copy everything, but find out which bits/bytes cause the lamp error messages to disappear, as the rest of the vehicle environment is usually also hardly identical.
Post16-12-2016, 15:40    Subject: Bordnetz Golf VII Quote
According to Ross-Tech, VCDS 16.8.4 in English already has a corresponding label file, please test the long coding assistant with the English VCDS version.
Hifigarage
Post20-12-2016, 18:42    Subject: Bordnetz Golf VII Quote
Hello, thank you for the tip, I tried it but unfortunately the same thing happened, too bad.
Best regards, Roy
Post20-12-2016, 20:47    Subject: Bordnetz Golf VII Quote
Please use the English version for Autoscan...
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Access denied: Golf V engine control unit (ECU) BLS On-Board Diagnostics (OBD)
No new posts Automotive Network Security Standards: Questions On-Board Diagnostics (OBD)
No new posts Audi A3 8P: Replace Body Control Module? On-Board Diagnostics (OBD)
No new posts Caddy: Onboard Network Coding Problem Solution Electrical Systems, Vehicle Electronics, Multimedia
