Immobilizer Control Unit
rschroe
Post17-12-2007, 16:42    Subject: Immobilizer Control Unit Quote
Hello.
I'm having a small problem with my 1994 Passat TDI (1Z).
For a while now, I've been experiencing increased fuel consumption, excessive black smoke, and a lack of power.
The error code indicates a difference in pressure regulation (on the control side).
Around 130 km/h, even a slight headwind or a small incline can cause the vehicle to lose a significant amount of power.
After losing the first motor two years ago due to a broken pulley, and the second rebuilt motor also having problems with the wobbly pulley (fortunately, there's this milling kit and people who know about it), I'm now also experiencing this power issue.
I know a lot of knowledgeable people, but this problem looks serious.
I have now replaced the magnetic valve for boost pressure regulation, the turbocharger, and all the pressure and vacuum hoses.
The air mass sensor is also working properly.
I simply patched the AGR valve using a piece of tin and a new gasket.
(Just to test if it's the EGR valve.)
A friend of mine (who works at VW) thinks it might be the intake manifold pressure sensor in the control unit, but who knows...?
This problem seems to have occurred before as well.
I received an engine control unit (ECU) from an Audi with a 1Z engine.
Part number matches, installed, and started.
The engine started, but then immediately shut off.
Problem: Immobilizer (anti-theft device) - my car doesn't have one!
Now, my question is, is there a way to bypass this?
Do you know the flow of funds, or does anyone have a diagram of it?
If anyone has any knowledge and can help me with this, please let me know.
I would be very grateful.
Screw.
Translated on 12-09-2026, 13:27.
Rudi
Post17-12-2007, 16:49    Subject: Immobilizer Control Unit Quote
The size may not have fit.
The Passat should have part number 028 906 021 B or 021 C.
Audi, possibly model 021 D.
The boost pressure sensor is located in the control unit.
What does the hose connecting the intake manifold to the STG (Steuergerät - control unit) look like?
If it's in good condition (tight and securely fastened at both ends), possibly.
Check the small hose in the control unit.
Rudi
Translated on 12-09-2026, 13:30.
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Document about errors in the start-up lock system of the ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 Immobilizer Control Unit On-Board Diagnostics (OBD)
No new posts Car Alarm System: AI & Immobilizer for Audi A6 4B Diesel Engine Technology
No new posts A6 2.5 TDI AEL Immobilizer On-Board Diagnostics (OBD)
No new posts Immobilizer Problem: Troubleshooting & Solutions Diesel Engine Technology
