Service Interval Display Panel Insert
jeanmaka
Post22-03-2017, 23:46    Subject: Service Interval Display Panel Insert Quote
Hello.
Unfortunately, I can't access the maintenance interval display on my Passat CC anymore; it just shows me this image.
It doesn't work manually either.
 File size:  37.23 KB
 Viewed:  1203 times
Log-AZ4093-36850km.txt
 File name:  Log-AZ4093-36850km.txt
 File size:  15.43 KB
 Downloaded:  786 times
Log-WVWZZZ3CZBE751638-36850km.txt
 File name:  Log-WVWZZZ3CZBE751638-36850km.txt
 File size:  1.58 KB
 Downloaded:  501 times
Translated on 24-07-2026, 12:59.
Post23-03-2017, 9:06    Subject: Service Interval Display Panel Insert Quote
Please provide an "Autoscan" so we know which control units are being referred to.
Otherwise, regarding the service delay:
Translated on 24-07-2026, 13:00.
No new posts VW Service Interval Display / Maintenance Indicator Technical Data
No new posts Audi Service Interval Display / Maintenance Indicator Technical Data
No new posts VCDS: Error on Maintenance Interval Display On-Board Diagnostics (OBD)
No new posts Diagnosis of relay box using VAG-COM Diesel Engine Technology
No new posts Switchboard Breaker Fault: Troubleshooting Guide On-Board Diagnostics (OBD)
No new posts Defective control panel insert? Electrical Systems, Vehicle Electronics, Multimedia
