SeatLeon Guest
20-12-2002, 20:14 Subject: Air bubble in fuel line - is it normal? |
'In my SEAT Leon TDI, I can see an air bubble in the transparent fuel line (from the diesel filter to the pump). When the engine is running, air bubbles regularly appear in the line. Should I take it to the workshop (under warranty), or is this not a cause for concern?'
Translated on 18-09-2026, 12:14.
Joined: 04/12/2002 Posts: 18117 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
20-12-2002, 21:40 Subject: Air bubble in fuel line - is it normal? |
Air bubbles during engine operation usually have simple causes, such as defective O-rings on the return valve, fuel lines that are not properly connected (or pinched) at the diesel filter, or a fuel filter that is too old (or clogged).
However, if you still have a warranty, it's likely the fuel filter, and it's probably the original one.
How many kilometers are on your car?
1. Fuel filter: yes or no?
If you have driven significantly more than 30,000 km, replace the filter and any O-rings on the return valve.
If the problem persists, I would recommend having it checked under warranty to find the leak. Issues like leaks in hard-to-reach places (e.g., a pipe inside the tank) can be difficult and time-consuming to locate.
Translated on 18-09-2026, 12:16.
Profile PM WWW Garage |
SeatLeon Guest
20-12-2002, 22:35 Subject: Used Car: 11,500 km / miles |
The car is only 4 months old and has 11,500 kilometers on the odometer.
How does it actually work? The pump surely pumps out more than is actually injected, right? Otherwise, I would surely notice the bubbles while driving, in the form of jolts, etc. Am I wrong in thinking that?
Translated on 18-09-2026, 12:17.
07-01-2003, 17:29 Subject: Air bubble in fuel line - is it normal? |
Yes, a variable displacement pump draws in more fuel than is actually consumed.
Translated on 18-09-2026, 12:18.
