RomanA6 Guest
22-12-2002, 16:00 Subject: Zahnriemenwechsel beim A6? |
Hi everyone!
Has anyone ever replaced the timing belt on the AFB engine themselves?
Does one also manage without the special tool or can one help oneself in another way?
For the 4-cylinder TDI, you can find the diagram of the fuel pump here. Does anyone have the diagram for the AFB V6?
Best regards.
Novel
GarfieldMZ Guest
22-12-2002, 20:46 Subject: What kind of chart do you have in mind? |
Hello Roman!
Are you referring to the complete instructions for the replacement, or the diagram for checking the dynamic injection start?
DENNIS
RomanA6 Guest
22-12-2002, 20:56 Subject: Zahnriemenwechsel beim A6? |
Instructions for the change are available. Do you have the diagram?
Have you ever done it?
Best regards.
RomanA6
GarfieldMZ Guest
22-12-2002, 21:00 Subject: No diagram! But... |
Hello Roman!
So, zunächst einmal, ich habe bisher nicht den Mut gehabt, beim AFB die Riemen zu wechseln. The effort seems considerable...
A diagram similar to the one in the 1Z doesn't seem to exist, at least not to my knowledge. However, I have a guide for checking the dynamic injection timing. If you wish, I can send them to you by email!
DENNIS
Michael II Profi-Schrauber
Joined: 04/12/2002 Posts: 1135 Karma: +3 / -0 Location: Stuttgart
22-12-2002, 21:33 Subject: Zahnriemenwechsel beim A6? |
Audi specifies the following special tool:
Special Order Part T40011
Countermeasure 3036
3242 Fixing Screw
Marking tool 3359
Camshaft retainers 3458
Without proper guidance, I wouldn't dare to do that. Tschüss
Michael II
RomanA6 Guest
25-12-2002, 18:12 Subject: Zahnriemenwechsel beim A6? |
hey everyone!
The tools themselves aren't really a problem, except for the following:
3242 Fixing Screw
Does anyone know if there's another way to get help?
Best regards.
roman
oldtimerdane Guest
08-01-2003, 22:49 Subject: Timing belt replacement A6 AFB |
Fix Screw 3242: Could someone possibly manufacture this on my lathe for a small fee, if they have the exact dimensions? Ideally, a technical drawing with the exact dimensions would be best. For increased interest, please email: [email protected]
If multiple interested parties inquire, I will also take care of the measurements.
haehnlein Schrauber
Joined: 08/22/2002 Posts: 877 Karma: +6 / -0 Location: Griesheim
08-01-2003, 22:53 Subject: Zahnriemenwechsel beim A6? |
RomanA6 wrote: | | 3242 Fixing Screw |
These tools can be found at www.matra.de.
Christian
