Tempomat does not work (Cordoba 6L2)
iann
Post26-01-2008, 20:44    Subject: Tempomat does not work (Cordoba 6L2) Quote
Finally, I tackled the cruise control.
Everything is installed and wired... so far so good.
With VAG unlocked ......the system also recognizes it
Only works if it doesn't.
OK, entered the measurement block ……… code 006 or 022 and tested
For each: / Each press of a key generates values.
Change as per the instructions.
000000 Cruise control off
000001 Cruise control on
000101 Press the button
001001 RES Position
100001 Clutch engaged
010001 Brake applied
until: 'Switch B to 'OFF', before the power-up point'
Nothing happens...no bit changes.
I don't really want to run, but I also don't want to stop.
Somehow, according to the installation instructions, the values should end with a 11.
(example =001011 RES Position and not like mine 0010(0)1)
Does this missing bit have anything to say, or is it simply STG dependent?
Does anyone know what might be causing this?
PS: I used the search function and found nothing. There was no one else with the same name.
Problem BUT also without a solution.
ioannis
Post27-01-2008, 13:46    Subject: Tempomat does not work (Cordoba 6L2) Translating...
[Translating...]
Die diagnose liefert Fehlermeldung
18097
Datenbus Antrieb unplausible Botschaft von elektronischer Zentralelektrik
P1689 -35-00
weis jemand was das sein kann
im netz finde ich nichts
vagtuning
Post27-01-2008, 15:02    Subject: Tempomat does not work (Cordoba 6L2) Translating...
[Translating...]Vermutlich fehlt die Leitung vom Bordnetz-STG zum Motor-STG.
No new posts Cruise Control Installation Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Tempomat (GRA) Golf 5/6/7, Retrofitting Procedure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Altea horn not working, cruise control Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cruise control not working (1Z) On-Board Diagnostics (OBD)
No new posts Cruise control not working Diesel Engine Technology
This topic is locked, you cannot edit or reply. Cruise control cannot maintain speed Diesel Engine Technology
No new posts The cruise control is still not working! ? Diesel Engine Technology
