boxerle
27-01-2008, 1:11 Subject: Control unit, need help!!! |
Hello everyone, I need your help.
After a long illness and the resulting unemployment, I have finally found work again. However, I now have to commute a relatively long distance and therefore had to buy an economical car. My choice fell on an older Passat Variant TDI (VIN 94, GL equipment).
Unfortunately, my current bank account doesn't allow for any more. The car actually seems to be in good condition (second hand, the previous owner had it for about 10 years and was almost 60, the AU and TÜV are almost new and without defects, okay, there are a few dents but what does it matter...). The only problem it has is the control unit. However, the seller told me about this before the purchase. The unit broke down three months ago and was replaced with another, used one (I have the invoice). The seller understandably didn't want to invest another €1000 in an original one. However, since the control unit is no longer original, the Passat now has two problems. First, a somewhat uneven engine speed at certain RPMs (which is best described as a kind of rapid vibration, almost like trembling), and second, he doesn't like to accelerate (at RPMs around or above 3000, regardless of gear) anymore. One must then maintain the speed and can then essentially accelerate gradually.
Currently, a control unit with the following part number (VW/Bosch) is installed: 028 906 021 B /
0 281 001 172/173. Previously (although the original date of manufacture, 18.11.97, may not be accurate... perhaps the original owner had replaced it), there was (the faulty control unit) 028 906 021 FC / 0 281 001 566.
I hope you can help me further. First, do the two faults really originate from the control unit (which I assume and hope), and secondly, and most importantly: Which control unit do I possibly need, or which one is compatible with my Passat (66kW, engine code IZ)?
Thank you in advance. I would really like to avoid going to the VW workshop. Firstly, due to the age of the car, and secondly, due to the exorbitant costs there.
Best regards, Andreas
Held467 Blaumann
27-01-2008, 1:34 Subject: Control unit, need help!!! |
Translating... |
[Translating...] Hallo
Was soll den an dem Alten defekt sein?
das Ruckeln wird ehr von nem verdrecktem Mengenstellwerk kommen.
Mfg. Dirk |
Ray-SB
Joined: 09/11/2007 Posts: 6 Karma: +0 / -0 Location: Saarbrücken 1994 Volkswagen Passat Free account, no CAN development support
27-01-2008, 12:45 Subject: Control unit, need help!!! |
Translating... |
[Translating...] Mengenstellwerk, Richtig, daher kommt das "Ruckeln".
Die Nachlassende Leistung über 3000U/Min lässt auf Druckverlust in der Ladeluftstrecke schliessen.
Also Undichtigkeiten ab Turbo, alternder LLM, nicht schliessende AGR, defektes N75, NBF oder von allem etwas, dürten die Ursachen sein. Evtl. auch Laderdefekt = LDA einbauen!!!
In den Fachartikeln findet sich eigentlich alles Nötige um die Defekte zu lokalisieren...
Habe meinen 1Z vor 4 Monaten mit den selben Symptomen gekauft, bis auf die Ruckelneigung, läuft er dank diesem Forum wieder astrein.
MFG Ray |
Profile PM Garage |
Tobi76 Blaumann
27-01-2008, 13:17 Subject: Control unit, need help!!! |
Translating... |
[Translating...] Hallo,
Deine Fahrgestellnummer wäre noch mal interessant. Gibt mehrere Steuergaräte.
Die Teilenummer ist bis auf die endenden Buchstaben gleich.
Wenn Du das Auto länger fahren willst ist die Anschaffung eines Diagnose Interfaces bestimmt interessant. Sonst kommt man hier nicht weit.
Erstmal die ganzen Unterdruckschläuche im Motorraum begutachten.
Für das Mengenstellwerk gibt es hier auch ein paar Tipps, mit Dieseleinspritzanlagenreiniger.
Hat bei meinem Golf 1Z auch geholfen.
Rußt Deine Kiste denn beim Beschleunigen? |
boxerle
27-01-2008, 17:21 Subject: Control unit, need help!!! |
Translating... |
also rußen tut er nicht beim beschleunigen.
Und die Identnummer ist: WVWZZZ3AZRE165360.
MfG Andreas |
Tobi76 Blaumann
27-01-2008, 18:23 Subject: Control unit, need help!!! |
Translating... |
028 906 021 FC sollte für Dein Auto das richtige sein. Da es für den 1Z aber mehrere Teilenummern gibt (FC/FF/AT Endungen) bin ich etwas überfragt wie die sich unterscheiden.
Ggf. sind die nur anders programmiert.
Vielleicht schickst Du das alte Gerät mal zum überprüfen ein. Vielleicht ist ja gar nichts defekt. |
