GOLF 3 Brake Drum ABS
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
lambdapapst
Post19-02-2008, 21:10    Subject: GOLF 3 Brake Drum ABS Quote
I need/have to replace the brake drums on my Golf 3. However, the new ones from the aftermarket supplier don't have an ABS sensor. Before I embarrass myself by potentially having the wrong parts or not knowing how to replace the ABS sensor, I'd rather ask about it publicly here.
Okay, let's be specific again. Are there different brake drums for vehicles with and without ABS? And if there is no difference, how is the sensor (not the sensor in the anchor plate!) modified?
Thank you for your help.
GOLF 3 GT SPECIAL TDI VARIANT, Bj.95, 1Z, ~390.000km
AGR Tot, Durchzug ~8,5sek, keine Bastelbude, kein Tuning
pax
Avatar-pax
2000 Volkswagen Passat
Post19-02-2008, 23:31    Subject: GOLF 3 Brake Drum ABS Quote
The flywheel is about to come loose.
Bye.
peace
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post19-02-2008, 23:43    Subject: GOLF 3 Brake Drum ABS Quote
That must be a perforated metal sheet; be careful not to bend it too much, otherwise it won't hold properly later.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
lambdapapst
Post26-02-2008, 18:50    Subject: GOLF 3 Brake Drum ABS Quote
Thank you for your help, it worked perfectly.
No new posts VW Golf PD, 150 hp, first registration 03/01 Diesel Engine Technology
No new posts Ladedruckanzeige bei GOLF IV TDI PD 100 Diesel Engine Technology
No new posts GOLF TDI PD 74 KW Verbrauchswerte??? Diesel Engine Technology
No new posts ABS-Leuchte VW-GOLF III On-Board Diagnostics (OBD)
