Bosch part number: gasket + screw for cover, quantity adjustment mechanism?
reuselkopp
Post19-02-2008, 9:04    Subject: Bosch part number: gasket + screw for cover, quantity adjustment mechanism? Quote
"This coming weekend, I'd like to clean my volume control knob because it's been acting up. My initial plan is just to remove the cover of the volume control and clean it that way. Since I assume the seal shouldn't be reused anyway, and it doesn't cost much, I want to replace it. Also, I'd like to replace the triangular screw with one of the other Torx screws."
Could someone please tell me the Bosch part number for the gasket or screw? I'd like to know the number beforehand so that the Bosch service center doesn't have to search for it for too long.
Greetings.
Reuselkopp.
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 14-07-2026, 9:45.
Boro
Post19-02-2008, 9:08    Subject: Bosch part number: gasket + screw for cover, quantity adjustment mechanism? Quote
So, for the seals, there's a repair kit available from Bosch that includes various or all of the seals for the specific pump and costs around €6.50. You just need to tell them which pump it's for, for example, the VP 37.
Translated on 14-07-2026, 9:46.
Post19-02-2008, 10:47    Subject: Bosch part number: gasket + screw for cover, quantity adjustment mechanism? Quote
My BOSCH always finds what it's looking for quickly.
They're sending me an exploded diagram with numbers indicating the parts, like 1, 2 (not part numbers).
I'll tell them I need the numbers 4.174 and 23, and then I'll get them.
It seems to depend heavily on the individual using the BOSCH computer as to whether they want to and are able to do it.
Translated on 14-07-2026, 9:47.
reuselkopp
Post20-02-2008, 9:59    Subject: Bosch part number: gasket + screw for cover, quantity adjustment mechanism? Quote
Hello everyone,
ich war gestern bei meinem Boschfuzzi. Eine halbe Stunde hat der Bosch-mensch gebraucht um die Teilenummern rauszufinden mit dem Ergebniss das ich für einen Satz Dichtungen und eine Schraube 14,64€ latzen musste. Was für eine Abzocke!!! icon_evil.gif
Let's hope that after the signal box is cleaned, the jolting will stop.
Greetings.
Reuselkopp.
PS: Is the entire fuel injection system (including the circuit board) exposed to diesel? I mean, does diesel immediately come into contact when you remove the cover, or is it only located underneath the circuit board?
Translated on 14-07-2026, 9:48.
Post20-02-2008, 9:59    Subject: Bosch part number: gasket + screw for cover, quantity adjustment mechanism? Translating...
[Translating...]
all in diesel
Boro
Post20-02-2008, 12:08    Subject: Bosch part number: gasket + screw for cover, quantity adjustment mechanism? Quote
'...Well, 14.64€ is still manageable...there are worse things...these sentences were already sold and bought privately on eBay for 30€...' icon_mad.gif
Translated on 14-07-2026, 9:49.
No new posts Quantity setting device and control path generator: Function Technical Articles
No new posts A3 8L Screw Corrosion: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts KW Seal Part Number & Gearbox Seal Search Diesel Engine Technology
No new posts Dichtung Pumpen Kopf Bosch VP 37 Diesel Engine Technology
No new posts 2,5TDI mit VP44: Wie den Deckel vom PSG abnehmen? Diesel Engine Technology
No new posts BKV Vacuum Hose Sealant Transmission, Chassis, Body & Interior
