KPower 3.0.6: Bug Fixes and Issues Resolved
moby
Post20-02-2008, 4:13    Subject: KPower 3.0.6: Bug Fixes and Issues Resolved Quote
Hello.
In version 3.0.6 of KPower, I immediately noticed a few bugs.
The first issue concerns saving and loading measurements. When I save a measurement, a file is created, but without the *.kpm extension. If I import this file, the data lines are mixed up. For example, the temperature appears under 'Pressure,' the engine power appears under 'Vehicle,' and the model year appears under 'Engine Code,' etc. This can be corrected by manually renaming the file.
I noticed another bug in the submenu 'Save diagram as graphic.' When I enter a filename and select '*.bmp' at the bottom, the saved file doesn't have a file extension. You have to change it manually.
Unfortunately, in the 'Print Diagram' section, I don't have the option to select a specific printer. It immediately sends the print job to the printer that is defined as the default. As a workaround, I simply changed the default printer. However, the program still redirects the print job to the previously defined default printer without restarting the program. Therefore, I have to restart the program again so that it recognizes which printer is currently the default.
If I print or save the measurement as a *.bmp file, the diagram appears, but there are no specific details about power and torque visible. The reader would have to read these values from the X and Y axes. It would certainly be clearer to include this information directly in the image.
Has everything been changed in version 3.0.7? Tests on other PCs yielded the same results. Unfortunately, I've only found the shareware version of 3.0.7. Where can I download the full version? In my account, only version 409.1 is offered, including KPower 3.0.6.
cu moby
Translated on 14-08-2026, 23:27.
Post20-02-2008, 14:28    Subject: KPower 3.0.6: Bug Fixes and Issues Resolved Quote
Please send me the invoice number and order name via private message (PM), and I will email you the latest version.
Thanks also for the tip about the 3.0.6 version in the 409 archive.
Translated on 14-08-2026, 23:30.
No new posts Bosch ESP 5.3: Error Codes & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and possible causes for Bosch ABS Version 5.0... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error codes and possible causes for Bosch ABS Version 5.3... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts [Poll] Weak Batteries: Cause of Electronics Malfunctions? Transmission, Chassis, Body & Interior
No new posts Different navigation versions? Diesel Engine Technology
No new posts Verschiedene Düsen für 1Z? Diesel Engine Technology
No new posts Different engine part numbers - what does each one mean? Diesel Engine Technology
