Alternative turbocharger for Audi A4 (B5) AFN engine
Manuel Thomas
Post28-12-2002, 20:37    Subject: Alternative turbocharger for Audi A4 (B5) AFN engine Quote
I have the following question:
Have any of you ever replaced the standard Garrett VNT 15 turbocharger with any of the following?
Garrett VNT 17 turbocharger, suitable for 130PS PD 1.9 TDI engines.
Garrett VNT 20 turbocharger, suitable for 150PS PD 1.9 TDI engines.
I'm asking because I'm interested in this modification, as it could make it easier to achieve the tuned boost pressure, and perhaps even increase it further.
Getting to the charging stations is the least of the problems. The problem is that on my B5, the VNT 15 turbocharger is only 0.8 cm away from the longitudinal support.
My question is now, will the others fit without touching the longitudinal support? Does anyone have technical specifications or diagrams for Garrett turbochargers?
Manuel.
Manuel Thomas
Post31-12-2002, 18:28    Subject: Alternative turbocharger for Audi A4 (B5) AFN engine Quote
Okay, apparently no one has done this conversion before!
However, I still have a question.
If I install the VNT 17 turbocharger now and connect everything, will my engine run as usual?
Does the VTG control system remain the same? Or do I need to replace the wastegate control valve for it to function properly?
I'm grateful for any response!
Manuel.
No new posts Timing belt replacement Audi A6 4F, BRE engine 2.0 TDI PD Troubleshooting & Guides
No new posts Audi A2 to A6, Engine Area, Generosity Policy Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Audi A4, Engine not starting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger for AVG Engine: Alternative Options Diesel Engine Technology
No new posts Removing the AUY engine's turbocharger from a Sharan? Diesel Engine Technology
No new posts Audi Q7 BUG Stellmotor Turbolader Diesel Engine Technology
No new posts 1Z Motor Audi 80 B4: Make the engine more fuel-efficient Diesel Engine Technology
