pschaefer Blaumann
20-12-2002, 23:08 Subject: TDI: How Fast to 90°C? (96 kW) |
Hello!
My Golf IV with a 96 kW PD-TDI engine doesn't reach its operating temperature of 90°C until after about 25 km, even when the temperature is -5°C.
My old 85 kW engine was much faster.
Given these outdoor temperatures, it's terrible (and it's only going to get worse).
(Just in case it ever drops to -10°C...) How long does it take for you?
What can be done about it?
Peter.
Translated on 23-10-2026, 17:30.
Bertil Profi-Schrauber
21-12-2002, 7:49 Subject: TDI: How Fast to 90°C? (96 kW) |
pschaefer wrote: | Hello!
(Just in case it gets down to -10°C...) How long does it take for you?
That's just the way it is when you drive a car with extremely high efficiency. The higher the efficiency, the less waste energy (heat) is produced.
"With my AXR, it takes about 20 kilometers to reach 90°C (without preheating). However, if I preheat it, it only takes about 5-10 kilometers to reach that temperature (measured at -7°C)."
Quote: |
What can be done about it? |
Preheat.
Take a look inside here: http://www.dieselschrauber.de/heizer.html
Translated on 23-10-2026, 17:32.
Markus H. Guest
21-12-2002, 14:26 Subject: Warm-up Time: How to Reduce It |
@pschaefer:
While 25 km is definitely a very long distance, as long as it reaches 90 degrees Celsius during normal operation, you can be relatively sure that, for example, the thermostat is not defective.
My 2.5 AAT also needs 20-25 km in this weather. But it also has to heat up a bathtub full of coolant...
@bertil:
That's a perfect timing, you bringing up these electric heaters.
I'm considering whether to install something like that instead of the incredibly expensive auxiliary heater.
Do you think something like that would also be useful for the 2.5?
Or would you have to preheat it for hours until the coolant reaches the proper temperature?
After all, it draws quite a bit of power from the outlet.
Translated on 23-10-2026, 17:35.
pschaefer Blaumann
21-12-2002, 16:21 Subject: TDI: How Fast to 90°C? (96 kW) |
Hm, I always thought TDIs had some kind of electric component.
Auxiliary heating (a few glow plugs)...
Probably not, right? Or at least, it probably won't do anything...
Okay, I'll take a look at some supplemental heaters.
Translated on 23-10-2026, 17:36.
Markus H. Guest
21-12-2002, 16:52 Subject: TDI: How Fast to 90°C? (96 kW) |
Yes, that's correct.
But first, they are quite weak, and second, they only provide heating during the worst cold-start phase.
I'm not sure, for example, whether my old AAT even has a glow plug heater.
Translated on 23-10-2026, 17:37.
21-12-2002, 20:03 Subject: Warm-up time: How to optimize it |
Markus H. wrote: | @bertil:
Or would you have to preheat it for hours until the coolant is hot?
After all, it draws quite a bit of power from the outlet. |
"No problem with the 2.5 either!!"
My brother had this in his 2.3L 5-cylinder gasoline engine, and it worked great!
The electrical power rating of the auxiliary heater is 550 or 600 watts (depending on the model). Therefore, with a heating time of one hour, the electricity consumption remains within reasonable limits.
Unfortunately, I can't comment on what happens when the car is parked outside, as I have a garage space (but still use the pre-heating function).
Translated on 23-10-2026, 17:38.
Markus H. Guest
21-12-2002, 21:36 Subject: TDI: How Fast to 90°C? (96 kW) |
Hi Bertil!
Mine also has its own dwelling (=garage)  .
That's why I also think that an electric heater is more useful than a standing heater.
The only disadvantage is, of course, that I don't have any preheating available in the afternoon/evening for the return journey.
Have you ever had any problems with that?
(I think that a complex auxiliary heating system is more likely to have problems than a Calix or Waeco pre-heater.)
Translated on 23-10-2026, 17:40.
22-12-2002, 9:26 Subject: TDI: How Fast to 90°C? (96 kW) |
Markus H. wrote: | ...
Of course, a standing heater is problematic in this situation, and an electric heater is definitely better (and cheaper).
das ist nicht ganz so schlimm, aber aus dem warmen Bett ins eisekalte nicht warmwerdende Auto ... Brrrrr.
(I think that the likelihood of problems is probably higher with a complex auxiliary heater than with a Calix or Waeco pre-heater) | .
Problems? With an immersion heater? I can't imagine there would be any problems with it.
However, there are two problems:
1 - Don't forget to remove the charging cable. When you're still half-asleep in the morning, it's easy to miss (and it can cause expensive damage). That's why I keep my charging cable right in front of the windshield, and I double-check it before I drive away. Alternatively, you can mount it in a way that it can easily be detached.
2 - Power outage at night, and the timer is stuck. Use a timer with a backup power supply (it's more expensive, but it's worth it).
Translated on 23-10-2026, 17:42.
Markus H. Guest
22-12-2002, 13:20 Subject: TDI: How Fast to 90°C? (96 kW) |
Hi Bertil,
You're absolutely right; immersion heaters aren't exactly complicated.
But the thought of forgetting to unplug something before leaving is not so far-fetched – it's even said to have happened with the fuel nozzle before.
http://hometown.aol.de/M%20Hoffmann2/Drivethr.jpg
(And NO, that sexist phrase is NOT from me!)
Okay, then it will be the immersion heater.
Translated on 23-10-2026, 17:44.
DocSnydor Guest
23-12-2002, 9:26 Subject: TDI: How Fast to 90°C? (96 kW) |
I have a heater from  Globus. It cost 24.95 DM back then (a space heater). For example, when it's -15°C, I turn it on an hour early, and the windshields are clear, and it's also warm inside. The only downside is that this thing uses 2000 watts  and the engine stays cold. A submersible heater is a much better solution.
Translated on 23-10-2026, 17:45.
Markus H. Guest
23-12-2002, 14:47 Subject: TDI: How Fast to 90°C? (96 kW) |
I have a Globus radiator in my bathroom.
But what's less important to me is that *I* am cold in the car. What I want to achieve is to prevent the engine from freezing.
That's why I ordered the immersion heater from the BOSCH service today, but the Waeco model, not the Calix one.
Once I've installed it (not before January 6th), I might briefly let you know what it's 'capable of'...
Translated on 23-10-2026, 17:46.
23-12-2002, 18:45 Subject: TDI: How Fast to 90°C? (96 kW) |
Markus H. wrote: | | ...but the one from Waeco, not the Calix part... |
... do you think they are different??? well, I couldn't recognize any differences  .
Translated on 23-10-2026, 17:47.
Markus H. Guest
24-12-2002, 0:55 Subject: TDI: How Fast to 90°C? (96 kW) |
Hi Bertil,
But of course, they are different.
On one it says 'Waeco', and on the other it says 'Calix'...
No, seriously: The BOSCH service actually offered Waeco products.
And I once found a test online that claimed the Calix had a higher heating output. I don't really care.
Translated on 23-10-2026, 17:48.
24-12-2002, 17:44 Subject: TDI: How Fast to 90°C? (96 kW) |
Markus H. wrote: | but of course, they are different:
One says "Waeco" and the other says "Calix"...
That's all there is to it. The supplier is the same!
Quote: |
No, seriously: The BOSCH service just offered Waeco products.
And on the internet, I once found a test that attributed a higher heating power to the Calix. | I don't really care.
... I was once at ACDC Motorwelt, and I think their review is nonsense because the Teles are definitely the same!
It doesn't matter what you get cheaper, it will be installed anyway!
Translated on 23-10-2026, 17:49.
Markus H. Guest
07-01-2003, 22:11 Subject: Heat Exchanger: Types, Applications & Benefits |
Hi Bertil,
I have now installed the Waeco immersion heater in the AAT.
This morning, I tested it for the first time, and it ran for 20 minutes.
In short: I'll probably have to run it for a significantly longer time to heat it up properly.
I'm a little concerned about the heating time.
Therefore, the question is:
Does this device have a fuse or a safety thermostat to prevent overheating?
I don't have any documentation for that part, so sorry for the silly question!
Translated on 23-10-2026, 17:50.
08-01-2003, 7:02 Subject: Heat Exchanger for Sale: Trade/Exchange |
Markus H. wrote: | Hi Bertil,
In short: I'll probably have to run it for a significantly longer time.
Hi Markus,
"20 minutes is definitely not enough. With my CALIX, there was a table included that specified the minimum time, ranging from 1 hour at 5-0°C to 3 hours at -20°C. I currently preheat for 1.5 hours."
If I can find the table, I'll post it here.
I don't have any documentation for that part, so that's why I'm asking this silly question! |
I'm not entirely sure either, but in order to obtain CE certification, this component requires such an overprotection mechanism.
According to the Calix instructions, overheating is not possible as long as there is cooling water in (or around) the heating device.
Translated on 23-10-2026, 17:53.
