KW Seal Part Number & Gearbox Seal Search
reuselkopp
Post09-03-2008, 18:35    Subject: KW Seal Part Number & Gearbox Seal Search Quote
"Since the ZMS (flywheel) on my car will be replaced soon, and I don't want to experience any unpleasant surprises, I want to purchase the crankshaft-side and transmission-side seals beforehand. I don't know if any of the seals are leaking, but I want to be prepared. Could someone provide me with the part numbers for these seals? The engine code is AFN and the transmission code is ASD."
Greetings.
Reuselkopp.
Golf 4 Variant Modell 05, ASZ mit 330000, ERF Getriebe, mit Zwangskorken, Softwareanpassung von Alex Günther
Golf 3 Variant Modell 98, AFN mit 281000km, ASD Getriebe, VNT15 mit großer Dose, ansonsten alles Original / verkauft
Translated on 10-09-2026, 17:08.
charlyfirpo
2013 Volkswagen Golf
Post09-03-2008, 23:06    Subject: KW Seal Part Number & Gearbox Seal Search Quote
Hello.
The sealing ring for the engine seems to be only available as a complete unit with the sealing flange.
028 103 171 B, approximately €52.
Regarding the gearbox side, the part number 085 311 113 should cost approximately 7 euros.
Just to be on the safe side, let's check with him again.
Best regards, Charly.
Golf 4 GTI TDI, ARL Serie 346031 Km
Webasto Thermo Top E
15.02.2013 -> Golf 6 GTD DSG CFGB/NLN, TT-V+T91R
21.03.2016 -> Golf 7 R, Limestonegrey, 19", Voll...
Translated on 10-09-2026, 17:09.
No new posts Replacing the Gearbox Seal between the Gearbox and the Dr... Troubleshooting & Guides
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts Explanation of the VAG part number Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Bosch part number: gasket + screw for cover, quantity adj... Diesel Engine Technology
No new posts Suche Teilenummer Transmission, Chassis, Body & Interior
No new posts Looking for resistor cable (or part number) for... H7 hea... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Suche Stecker-Teilenummer für Druckwandler 1J0906627A Diesel Engine Technology
