Doku Polo MJ 2001, Clutch pedal remains at the bottom (Solution)
Michael II
Post01-01-2003, 12:52    Subject: Doku Polo MJ 2001, Clutch pedal remains at the bottom Quote
Polo MJ 2001
The clutch pedal remains on the floor after completing a right-hand turn.
Cause:
Play at the crank shaft outside of tolerance.
Solution:
Inspect the pedals and hydraulic clutch actuation for damage and leaks, and repair as necessary.
Measure the play (or clearance) at the crank shaft. Is the axial play on the crankshaft too large, requiring repair measures to be initiated?
Tschüss
Michael II
Ratings - Doku Polo MJ 2001, Clutch pedal remains at the bottom
No new posts Doku Golf 1J1214, Clutch pedal remains at the bottom Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo Convertible Alarm: 2001 Doku & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Various Driving Behavior Defects Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 clutch pedal stays down Transmission, Chassis, Body & Interior
No new posts P-Box: Differences Explained Diesel Engine Technology
No new posts How close can Nm and Russian borders be to each other? On-Board Diagnostics (OBD)
No new posts Diesel Filter: Causes of Engine Surging? Diesel Engine Technology
