Doku Polo MJ 2001, Climatronic display blinking (Solution)
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
Michael II
Post01-01-2003, 13:46    Subject: Doku Polo MJ 2001, Climatronic display blinking Quote
Polo MJ 2001
The Climatronic display is flashing.
Cause:
Cable harnesses for the manual air conditioning system were installed in vehicles with Climatronic. The Climatronic is fully functional, but the error "00792 - Pressure switch for air conditioning F129" is displayed in the Climatronic control unit.
Solution:
Checking the connections from the Climatronic control unit to the radiator fan control unit. From T16b/2 to T14c/12 and from T 12/2 to T14c/8. If these lines are not present, they must be installed retroactively.
Removal of the T14c/3 line from the cooling fan control unit to the engine control unit.
Check if the vehicle has the F38 external temperature switch. If present, please remove them and connect the wires together.
Tschüss
Michael II
Ratings - Doku Polo MJ 2001, Climatronic display blinking
No new posts Doku Polo MJ 2001, Alarmauslösung bei Faltdach Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, Various Driving Behavior Defects Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Polo MJ 2001, EFH ohne Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts When using the Climatronic, the display is blinking. Transmission, Chassis, Body & Interior
No new posts Geheime Funktionen der Climatronic im Polo 9N Diesel Engine Technology
No new posts It is impossible to clear the error code for the V71 serv... Dieselschrauber Bar
No new posts Wegfahrsperrelampe blinkt !!!!!!!! On-Board Diagnostics (OBD)
