Bleed Brake Mk 20i
Jockel
Karma: +15 / -1   Thank you, like it!
Post18-03-2008, 15:25    Subject: Bleed Brake Mk 20i Quote
Mashlzeit!
I want to install a Mk 20i ABS/EDS system.
As far as I understand, you need both hardware and software to perform the bleeding process.
Does the following product from the Dieselschraubershop suffice for that purpose?
"Ready-to-use VAG-COM diagnostic adapter KKL"
Or do you need something else?
Hi, Jockel.
"Neu": Bora Variant, ASV
Translated on 25-09-2026, 10:12.
Back to top Profile PM Email
Held467
Post18-03-2008, 21:08    Subject: Bleed Brake Mk 20i Quote
Hello.
The standard version is sufficient, but the MK 20i model doesn't yet have CAN functionality.
Dirk
Translated on 25-09-2026, 10:13.
No new posts Electric Brake (EPB) Diagnosis and Maintenance Troubleshooting & Guides
No new posts Document Passat, Model Year 2000, Brakes Stuck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Bremse Passat Neu On-Board Diagnostics (OBD)
No new posts R32 Rear Brakes for 85kW TDI? Transmission, Chassis, Body & Interior
No new posts Sharan 7N1 Brake Parts & Accessories Transmission, Chassis, Body & Interior
No new posts Funny Brake: Troubleshooting & Repair Guide Transmission, Chassis, Body & Interior
