Lupo Vibration: 6X1 MJ 2002 Doku & Repair (Solution)
Michael II
Post01-01-2003, 14:50    Subject: Lupo Vibration: 6X1 MJ 2002 Doku & Repair Quote
Vibrations in the steering wheel at speeds of 100-110 km/h.
(Only tires in size 185/55 R14 on a 6J x 14 rim with an offset of 43.)
Cause:
"Tolerance deviations in steel wheels and full wheel covers, disc brake run-out, excessive wheel imbalance due to potential distortion or play in the wheel hub."
Solution:
Operating the vehicle without activating the full wheel illumination.
Is the vehicle in good condition? Replace the wheel trims.
Is the issue still present even without full wheel rotation? Balance the wheels and, if necessary, match them.
Attention! When mounting the wheels, ensure they are centered correctly.
Recommendation: Before mounting the wheel, apply a layer of Tesa crepe paper around the wheel hub. Mount the wheel using the wheel bolts. Then, remove the crepe paper (the crepe paper reduces the clearance between the wheel hub and the center hole of the rim).
Tschüss
Michael II
Translated on 21-10-2026, 14:13.
Ratings - Lupo Vibration: 6X1 MJ 2002 Doku & Repair
No new posts Lupo 6X1 MJ 2002: Clicking Noise Diagnosis Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo Dents: 6X1 MJ 2002 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo Doku: Door Lock Noises - MJ 2002 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the steering wheel of a 2009 VW Passat B6 with ... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Steering wheel replacement Transmission, Chassis, Body & Interior
No new posts TT Steering Wheel 2006 Transmission, Chassis, Body & Interior
No new posts Steering Wheel Noise: Causes & Solutions Diesel Engine Technology
