Lupo Doku: Door Lock Noises - MJ 2002 (Solution)
Michael II
Post01-01-2003, 15:10    Subject: Lupo Doku: Door Lock Noises - MJ 2002 Quote
Sounds from door locks.
Cause:
In some vehicles, door lock noises can occur due to load changes.
Solution:
Spare part.
Only the index has changed in the new clamping devices.
No. 3B0 837 033 (where the letters in index E, G, Q change to K, and the letters in index D, F, P change to J).
In addition, the following needs to be done:
1. With the door open, clean the locking surfaces that come into contact with the locking bar on the body frame.
2. The contact surfaces of the locking bar on the body frame also need to be cleaned.
3. The castle grounds should be sprayed with product number D 007 000 A2.
The amount is determined by the maximum spraying time of one second.
4. When carrying out the procedure, it is essential to protect the door panels from overspray to avoid permanent staining.
5. After spraying, the doors remain open for a few minutes.
Tschüss
Michael II
Translated on 24-09-2026, 1:09.
Ratings - Lupo Doku: Door Lock Noises - MJ 2002
No new posts Doku Lupo 6X1 MJ 2001, Dashboard Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Lupo 6X1 MJ 2001, Door panel noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo MK4 AC Noise: Diagnosis & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Turbocharger Sounds: What to Listen For Diesel Engine Technology
No new posts PD AUY Noises: Troubleshooting & Solutions Diesel Engine Technology
No new posts Blubber Sounds: What Causes Them? Diesel Engine Technology
No new posts Sounds of A4 driver's door Transmission, Chassis, Body & Interior
