Signal horn, no function.
Cause:
Loose connectors.
2. Loose connection of the signal horn.
3. Contact problems caused by oxidation on the contact surfaces (only affects vehicles that have been stationary before delivery).
Solution:
Check the electrical connectors and fittings of the signal horn. If a malfunction of the signal horn is detected during the handover inspection, the horn contact should be activated several times (activation duration: 5-10 seconds).
If the function is still impaired, the signal horn should be replaced. Tschüss
Michael II
Translated on 15-09-2026, 22:39.
