Lupo 6X1 MJ 2002: Horn Not Working (Solution)
Michael II
Post01-01-2003, 16:18    Subject: Lupo 6X1 MJ 2002: Horn Not Working Quote
Signal horn, no function.
Cause:
Loose connectors.
2. Loose connection of the signal horn.
3. Contact problems caused by oxidation on the contact surfaces (only affects vehicles that have been stationary before delivery).
Solution:
Check the electrical connectors and fittings of the signal horn. If a malfunction of the signal horn is detected during the handover inspection, the horn contact should be activated several times (activation duration: 5-10 seconds).
If the function is still impaired, the signal horn should be replaced.
Tschüss
Michael II
Translated on 15-09-2026, 22:39.
Ratings - Lupo 6X1 MJ 2002: Horn Not Working
No new posts Doku Lupo 6X1 MJ 2002, Heizungsregulierung ohne Funktion Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, Window lifter not functioning Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Seat Altea horn not working, cruise control Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Correct oil for AWX engine, year 2002, without DPF Diesel Engine Technology
No new posts ASR Not Working: Troubleshooting & Fixes Transmission, Chassis, Body & Interior
No new posts ESP not working On-Board Diagnostics (OBD)
No new posts Fresh air blowers without function On-Board Diagnostics (OBD)
