Fuel Injector Replacement: Stuttering, Power Loss, Misfire
verdiener
Post18-04-2008, 18:42    Subject: Fuel Injector Replacement: Stuttering, Power Loss, Misfire Quote
Today, after 300,000 km, I had the fuel injectors replaced in my Passat 1.9L with an 81kW AFN engine, hoping to do something good for the car.
The built-in nozzles are also used, but they are supposed to have been refurbished.
Now I press the accelerator, but nothing happens --> loss of power.
When accelerating, there's a significant jolt, and the engine is making a knocking sound.
There are no error codes stored. What could be the reason for that? Could the injectors be faulty?
Please help me; I'm not very knowledgeable in this area.
Martin.
Translated on 18-08-2026, 12:21.
Held467
Post18-04-2008, 19:50    Subject: Fuel Injector Replacement: Stuttering, Power Loss, Misfire? Quote
verdiener wrote:
have been overtaken
Re-install the old ones or let the "new" ones be printed and check the spray pattern.
Translated on 18-08-2026, 12:22.
Post18-04-2008, 21:13    Subject: Fuel Injector Replacement: Stuttering, Power Loss, Misfire Quote
Why don't you mention where you had the nozzles exchanged and who manufactured them? I would say that, in your case, you are the right person to provide that information.
Translated on 18-08-2026, 12:23.
No new posts Fuel injector replacement: Tuning without electronic modi... Technical Articles
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Document, 2.5 l, 6-cylinder / Jerking/Hesitation Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Komischen Klackern Nach Einspritzdüsentausch! Diesel Engine Technology
No new posts A6 2.5 TDI BDH Ruckeln und Nageln im Leerlauf Diesel Engine Technology
No new posts Low Power/Torque, Poor AFR: Troubleshooting Guide Diesel Engine Technology
No new posts 1.9 TDI rapid power loss, severe knocking Diesel Engine Technology
