Lupo 6X1094 AMF MJ 2000: Whining Noise Diagnosis (Solution)
Michael II
Post01-01-2003, 15:51    Subject: Lupo 6X1094 AMF MJ 2000: Whining Noise Diagnosis Quote
AMF engine.
"Scratching noises coming from the front right side of the engine compartment."
Cause:
The noises are caused by the membrane fluttering of the hydraulic engine mount on the front right side and occur at approximately 750 Hz. The membrane system vibrates with varying intensity and is dependent on the road surface and the temperature of the engine mount.
The noise is very noticeable when the system is warm and only occurs on uneven road surfaces and bumps. The sound can be compared to the noise of a timing belt. It's a bright, high-frequency knocking sound.
Solution:
The engine mount needs to be replaced if the following criteria are met:
The noise is more noticeable when the device is warm.
The noise is only noticeable when driving over bumps or on uneven road surfaces.
The noise occurs even when the device is disconnected and under no load.
In the event of a complaint, please use the optimized engine mount with part number 6N0 199 167 BF.
TschĂźss
Michael II
Translated on 30-08-2026, 23:40.
Ratings - Lupo 6X1094 AMF MJ 2000: Whining Noise Diagnosis
No new posts Doku Lupo 6X1 MJ 2000 - Howling noises from timing belt d... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentation Lupo MKB AYZ, problems with driving behavior Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo Fuel Issues: Documentary Until Feb 10 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo: Performance Tuning & Engine Upgrade Diesel Engine Technology
No new posts Fuel consumption on the Lupo 3L Diesel Engine Technology
No new posts TDI Flywheel: Will it fit Lupo 1.4 AMF? Diesel Engine Technology
No new posts Lupo 6X Alarm System On-Board Diagnostics (OBD)
