Airbag Warning Light: VW Passat B5 A2 (2003) Fix (Solution)
Michael II
Post01-01-2003, 17:17    Subject: Airbag Warning Light: VW Passat B5 A2 (2003) Fix Quote
Airbag warning light is illuminated.
Error code: 00588 Driver-side airbag inflator - upper limit exceeded. The error may be static or intermittent.
Cause.
Dirty or damaged connector pins.
Solution:
To achieve a sustainable and successful repair for the described issue, the following steps must be completed:
• Renewing the retaining ring.
• Renewing the airbag wiring harness in the steering wheel.
• Reconnect the connector that is plugged into the reset ring on the vehicle side. Part number of the contacts: 000 979 015 A.
• When performing repairs, it is especially important to maintain cleanliness.
• The affected contacts should be connected only once if possible, as each connection increases the likelihood of damage to the gold contacts.
• The wiring harness in the steering wheel must not be pinched between the steering wheel and the airbag module.
• Only gold contacts are permitted in the airbag system.
Tschüss
Michael II
Translated on 16-08-2026, 14:50.
Ratings - Airbag Warning Light: VW Passat B5 A2 (2003) Fix
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 1 - View ratings
No new posts Document A2 8Z0 MJ 2003, noises from the front of the car Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A2 8Z0 MJ 2003, Hands-free device malfunction Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2003, broken rear spoiler Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ESP warning light is on. Audi A6 2.5 TDI AKE 132kW, 2003 On-Board Diagnostics (OBD)
No new posts Passat 3BG mit BDH Motor Fehlerlampe/Notlauf Diesel Engine Technology
No new posts Replace Airbags After Accident - Save Money! Diesel Engine Technology
This topic is locked, you cannot edit or reply. Airbag Warning Light On? Deactivate Airbags? On-Board Diagnostics (OBD)
