Audi A2: Dashboard shows only range (Solution)
Michael II
Post01-01-2003, 16:49    Subject: Audi A2: Dashboard shows only range Quote
The onboard computer only displays the estimated range, and it is not possible to cycle through other functions using the switch on the wiper stalk.
Only VDO manufacturers with driver information systems.
Cause:
Incorrect adjustment performed in channel 18 of the terminal block module during manufacturing.
Solution:
Change the adjustment value in channel 18 of the switchboard module to XXX0X (leave the X values unchanged).
Tschüss
Michael II
Translated on 22-09-2026, 7:13.
Ratings - Audi A2: Dashboard shows only range
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 1 - View ratings
No new posts Wind Noise in Audi A2 (8Z0) 2002: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A2 Noises: 8Z0 MJ 2002 Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A2 8Z0 MJ 2002, HVAC failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Range Webasto T70/T90 Transmission, Chassis, Body & Interior
No new posts 1Z Measurement Block 13: What Does It Show? On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Fuel Injection Timing: Diagnostic Tool Results Diesel Engine Technology
No new posts MFA: 3x Higher Than Average Consumption Diesel Engine Technology
