Tailgate locks
Post27-05-2008, 10:14    Subject: Tailgate locks Quote
Hi.
Are the rear hatch locks on Volkswagen vehicles generally similar?
Can I, for example, use a latch from a used Volkswagen Golf 3 Variant to replace the latch in a Volkswagen Passat 3C?
I want to build a sturdy adapter so I can drive with the valve partially open sometimes.
I need a wedge and a lock for that, and preferably at a reasonable price, so used would be ideal.
"Thank you."
m
Translated on 19-07-2026, 3:27.
Wiesel
Post27-05-2008, 11:17    Subject: Tailgate locks Quote
Hi Martin,
From the gut - no.
My dog leash clip, which fit perfectly on the G III, only fits with...
to probe and thread, to latch on.
Best regards, Micha.
Translated on 19-07-2026, 3:28.
Post27-05-2008, 11:31    Subject: Tailgate locks Quote
Hmm.
30 EUR for an organic 3C lock (with a 1K number icon_smile.gif) would still be acceptable.
Translated on 19-07-2026, 3:29.
Post27-05-2008, 15:37    Subject: Tailgate locks Quote
Micha.
Do you have something like that?
http://www.womo-voets.com/shop/images/product_images/popup_images/90_1.jpg
Wiesel
Post27-05-2008, 17:17    Subject: Tailgate locks Quote
Similar, but with a threaded fitting in the middle.
Translated on 19-07-2026, 3:30.
Post28-05-2008, 20:44    Subject: Tailgate locks Quote
Okay,
The wedge is 13 mm thick. I should be able to get something like that welded together.
The entire arm should be 80 cm long (or adjustable). At this maximum length, the flap is horizontal and already starts to move in the open direction, so it shouldn't rattle too much (the Sportline suspension will still handle it icon_sad.gif).
I'm still unsure about how to connect the locking mechanism to the vehicle's latch. I'm wondering if a simple "S" shaped connector will suffice, or if I should use a proper tailgate lock, which would fit much more precisely and neatly.
Translated on 19-07-2026, 3:31.
