ASV Error: 'Engine Speed Sensor G80 - No Signal' (Solution)
Karma: +807 / -0   Thank you, like it!
Post02-05-2008, 17:29    Subject: ASV Error: 'Engine Speed Sensor G80 - No Signal' Quote
The non-resolvable error 'Motor speed sensor no signal' on the ASV motor has nothing to do with the sensor itself.
In this specific case, a faulty needle position sensor, likely due to a short circuit, probably caused two errors: the NHG error (error code: 16705) and the engine speed sensor error. Typically, the first one could be deleted and did not reappear for some time, which resulted in a lot of wasted effort trying to fix the second error.
-> In case of doubt, refer to the NHG for clarification.
Ratings - ASV Error: 'Engine Speed Sensor G80 - No Signal'
No new posts P0321 Error: Faulty Crankshaft Sensor (VAG) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Low turbocharger pressure sensor signal error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P0101 Error Code: Mass Air Flow Sensor Problem Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Touran Crankshaft Position Sensor - Faulty Signal Diesel Engine Technology
No new posts A4 2.5 TDI G28 - No Signal Diesel Engine Technology
No new posts Fuel Shutoff Valve (ALE) No Signal: Troubleshooting On-Board Diagnostics (OBD)
No new posts T4 ACV performance only from 2500 RPM, no MAF signal On-Board Diagnostics (OBD)
