Golf IV Cold Start Error: Codes 17831 & 18
RedFox1714
Post27-06-2008, 13:15    Subject: Golf IV Cold Start Error: Codes 17831 & 18 Quote
I have a Golf IV 1J, manufactured in 1999, with 42,000 kilometers on the odometer.
"Occasionally, when starting the engine cold, I experience a problem where, after the initial throttle input, the engine RPM fluctuates between 850 and 1200 before settling down. After about a minute, it returns to its normal idle speed and maintains it consistently. However, it's impossible to drive the car within that first minute."
At first glance, all the cables and hoses appear to be in good condition. Therefore, I checked the error memory, and the following result was obtained: -> VAG-COM version: Release 303.1
Control Module Part Number: 06A 906 033
Component and/or Version: SIMOS33 1.6l 2V 00HS3087
Software Coding: 00031
Workshop Code: WSC 00046
2 Faults Found:
17831 - Secondary Air Injection System: Bank 1: Insufficient Flow.
P1423 - 35-00 - -
18056 - Powertrain Data Bus: Failure.
P1648 - 35-10 - - - Intermittent
I've already done some searching, but I haven't found anything specific about the errors.
Thank you in advance for the information.
g ^^
Translated on 18-10-2026, 3:32.
Post27-06-2008, 13:56    Subject: Golf IV Cold Start Error: Codes 17831 & 18 Quote
I often find the throttle body completely covered in dirt, as the crankcase ventilation system (KGE) connects directly to it... do you think it will help?
Translated on 18-10-2026, 3:34.
RedFox1714
Post28-06-2008, 21:26    Subject: Golf IV Cold Start Error: Codes 17831 & 18 Quote
Unfortunately, not... it wasn't really dirty icon_sad.gif.
No new posts Document: Golf 1J, from week 48/98, Clattering noise afte... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Golf V/VI and similar models: ABS/ESP error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Golf 1J, Problem with the ignition lock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 3 TDI: Cold Start Problems & Solutions Diesel Engine Technology
No new posts Golf IV 1.6 Problems / Issues On-Board Diagnostics (OBD)
No new posts ABS Error Golf 4 SDI: Troubleshooting Guide Transmission, Chassis, Body & Interior
No new posts Golf III TDI AHU: Common Problems & Fixes On-Board Diagnostics (OBD)
