Hello Olli,
The new GRA switch I bought failed after less than a year. I suspect that some loose metal contacts inside might be causing the sporadic errors you're experiencing.
Of course, your wiring might also be loose or not properly insulated from each other.
As soon as the clutch pedal switch
or brake pedal switch is activated, the GRA turns off. However, this does not create an error entry.
/viewtopic.php?t=807&highlight=switch+settings
