moto
Joined: 07/22/2008 Posts: 2 Karma: +0 / -0 Location: Waltrop
22-07-2008, 12:10 Subject: Controlling the injection timing (AFN) with shareware VAG-COM |
Hello screw experts,
I have a Passat TDI AFN, with 110 horsepower, and I also own the shareware version of VAG-COM, which unfortunately doesn't have the TDI graph feature unlocked.
Do I now, after a timing belt replacement, have the possibility to check or adjust the injection timing based on the data blocks (injection duration, fuel temperature, etc.)? It should ideally work so that the TDI graph only displays measured values graphically.
What values should be displayed here for the corresponding fuel temperature?
Does anyone happen to have any tables related to this?
I hope for your support.
Best regards, moto.
Translated on 06-07-2026, 14:20.
22-07-2008, 15:33 Subject: Controlling the injection timing (AFN) with shareware VAG-COM |
It's not just about the advertisement.
The main issue is to "disable" the injection start control so that the adjuster is at the limit and the pump can actually be adjusted, rather than everything being automatically regulated out immediately.
If you are not in "basic settings mode," you should not adjust the pump.
Translated on 06-07-2026, 14:21.
Profile PM Garage |
Wiesel Profi-Schrauber
Joined: 04/06/2008 Posts: 896 Karma: +43 / -0 Location: Schleswig-Holstein
22-07-2008, 15:43 Subject: Controlling the injection timing (AFN) with shareware VAG-COM |
IIRC (assuming this is the full version), that doesn't work with shareware, as neither...
While in the default settings mode, display group 0 is still enabled, which is used for configuring the...
Injection start is required. In "normal operation," as indicated by Martin's specifications, ...
Do not create.
Best regards, Micha.
Translated on 06-07-2026, 14:22.
moto
29-07-2008, 9:51 Subject: Controlling the injection timing (AFN) with shareware VAG-COM |
Thank you Dieselmartin and Wiesel for your comments.
I am a very pragmatic person.
Therefore, here's another idea. In a measurement block (was it the 004?, I don't remember exactly), there were readings showing the ice injection times. If I now rotate the pump in both directions until the value changes, and then select the middle position between these two positions, shouldn't there be enough leeway for automatic regulation? What do you think about it?
Furthermore, I found information in a forum suggesting that the sampling rate should be below 90% at 4000 RPM, which could be a rough guideline. Could you please say something about this?
Thank you very much!
moto
Translated on 06-07-2026, 14:23.
