Octavia RS TFSI: Top Speed Problem (2008)
Go to page: 1, 2  Next
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
DieselSchlumpf
Post19-01-2009, 15:23    Subject: Octavia RS TFSI: Top Speed Problem (2008) Quote
Hello everyone.
I hope there are some tips here that can help me figure out how to identify and solve a potential problem.
Here's the translation:
It's about a Skoda Octavia TFSI, manufactured in August 2008.
The vehicle does not reach the maximum speed of 238 km/h stated in the registration document.
Measured with GPS: 236. According to the speedometer: just about 245/250, +/- depending on the "weather conditions."
Standard tire size: 225/40/18.
Well, one might think, what's the big deal about just 2 km/h?
It's about the principle. Nothing more, nothing less.
According to some reports from other TFSI (Octavia) drivers, the 2006/2007 models are generally reaching speeds close to the speedometer's maximum (270 km/h).
"Now I've made contact with 3 users who also have 2008 models, and they're only achieving speeds of 240/250 Mbps, just like mine."
Comparable vehicles with 250 horsepower actually achieve 250 horsepower.
You almost instinctively nod your head when you see a reading of 245, as if something is "holding it back."
But even increasing the performance didn't help.
Wendland, A-B-T, and ****4***** have already "attempted" to do so...
I had the vehicle tested four times, and it produces 261 horsepower according to DIN standards.
The shut-off valve has already been replaced, but it didn't solve the problem.
The car consistently reaches 250 km/h in both directions on my test track.
(If not, then preferably 245.)
The performance is quite good up to 240. At 245, it only reaches 250 over a distance of 12km, and beyond that, there's absolutely no further improvement.
I've now bought myself a VCDS.
Can anyone give me some tips on what I can use VCDS to check for in order to potentially identify a problem?
Exhaust gas temperature, boost pressure, fuel injection quantity, etc. If possible, please indicate where I can find these measurement blocks.
Thank you very much.
The diesel clunker... (I should have stuck with the TDI, haha).
Translated on 02-09-2026, 10:11.
Benni
Post19-01-2009, 15:42    Subject: Octavia RS TFSI: Top Speed Problem (2008) Quote
Is it possibly deactivated? Newer TDI models also have DPFs.
It should be in a measurement block within the engine control unit (ECU). (I don't know which one.)
Passat Variant Highline 3BG EZ 2/04 2,0 TDI mit DPF 235tkm 2x DPF gespĂŒlt - RIP dank LKW
Translated on 02-09-2026, 10:14.
DieselSchlumpf
Post19-01-2009, 15:48    Subject: Octavia RS TFSI: Top Speed Problem (2008) Quote
Since the series is supposed to only have 238 episodes, I would be very surprised if there was any kind of manipulation or interference involved.
But that's exactly what I suspect, but the question is how to find out, and that's where YOU icon_smile.gif come in.
mserge
Post19-01-2009, 15:51    Subject: Octavia RS TFSI: Top Speed Problem (2008) Quote
Yes, exactly. Check the fuel injection amount at maximum speed. If it's being reduced, then you'll know what the problem is, whether it's a low load torque (LLT) setting that's too high, or something else.
Perhaps it's simply normal. After all, who looks at a difference of 2 km/h? There's always some deviation from what's displayed. Not every engine performs equally well or poorly. I've also heard something about a throttle in the transmission – maybe that's related?
How many revolutions per minute (RPM) are there at maximum speed? Is it just before the redline?
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 02-09-2026, 10:15.
DieselSchlumpf
Post19-01-2009, 15:58    Subject: Octavia RS TFSI: Top Speed Problem (2008) Quote
No, it's currently running at around 5900 RPM. There's still about 1000 RPM of headroom in terms of the gear ratio.
2 km/h isn't much. But we're talking about 2 km/h that are missing from the standard performance.
I have 60 horsepower more than the standard model, but the car runs like a dream at approximately 250 km/h ( speedometer).
According to the registration, my car should have 240 horsepower.
It can reach a top speed of 245 km/h, but the actual speed is 236 +/- 1-2 km/h.
With 270 horsepower, it is said to actually reach a top speed of 252 km/h.
I have 261 horsepower, but it's still only running at "just" 236 +/-.
(source: A-B-T performance data sheet...guaranteed data)
I understand that every kilometer per hour requires power proportional to the square of the speed.
But with 260 horsepower with that gearing, it should be capable of more than 236 km/h.
Translated on 02-09-2026, 10:17.
mserge
Post19-01-2009, 16:08    Subject: Octavia RS TFSI: Top Speed Problem (2008) Quote
Are you absolutely sure it doesn't lose power at higher RPMs (no, I'm not talking about misfires, just in terms of power output)? At what RPM does it produce the power you're quoting? A tuned turbocharged gasoline engine is very sensitive in the higher RPM range. To make it more durable, it's often detuned or over-fueled to prevent internal overheating. Ask the tuners if they allow it to run freely at the top end or if they revert to the original data in that range. They don't want to risk damaging it either. Maybe you're achieving maximum power at the RPM where you reach your top speed, and after that, the power decreases, and the engine can't rev any higher. Upload your power curve diagram here, and I'll take a look.
Translated on 02-09-2026, 10:19.
Post19-01-2009, 16:21    Subject: Octavia RS TFSI: Top Speed Problem (2008) Quote
Take a look at the maximum speed that the engine control unit is reading.
Record it, of course, because you shouldn't be looking at your laptop while driving!
I bet VCDS shows 238 km/h in the engine control unit. If that's the case, and you want to go faster, you can contact me through the shop contact form. Due to time constraints, I can't read every topic in the forum.
Translated on 02-09-2026, 10:21.
DieselSchlumpf
Post19-01-2009, 16:35    Subject: Octavia RS TFSI: Top Speed Problem (2008) Quote
I can test and record the VMax with the standard performance settings again tonight.
I'll put the diagram online.
If I remember correctly, the maximum power is specified at 5840 RPM.
It could be considered a "problem" or a reason. But then, wouldn't the other Octavias be able to run "faster" than 20 km/h? icon_smile.gif
Can I log speed, RPM, and fuel injection volume simultaneously, along with the data that the engine control unit (ECU) is already recording, or do I need to make two separate trips?
Translated on 02-09-2026, 10:22.
mserge
Post19-01-2009, 17:06    Subject: Octavia RS TFSI: Top Speed Problem (2008) Quote
If other Octavia models have a different control unit, then that could certainly be the reason, but they will likely end up stuck on the road sooner or later.
Translated on 02-09-2026, 10:23.
vagtuning
Post19-01-2009, 18:29    Subject: Octavia RS TFSI: Top Speed Problem (2008) Quote
Now that you have access to a vehicle diagnostic tool, you could post a scan report, at least of the engine, and possibly the transmission if it's a DSG.
DieselSchlumpf
Post20-01-2009, 2:03    Subject: Octavia RS TFSI: Top Speed Problem (2008) Quote
Here's my scan:
Monday, January 19, 2009, 11:57:31 PM: 03251
VCDS Version: RKS 805.1
Data as of: 20081206.
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Vehicle type: 1K0
Scan: 01 03 04 08 09 15 16 17 19 25 37 42 44 46 47 52 55 56 62 72
76
Vehicle Identification Number: TMBUF61Zxxxxxxxx Mileage: 16410 km
01-Motor -- Status: OK 0000
03-Brakes -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate/Heating -- Status: OK 0000
09-On-board network -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-inch steering wheel -- Status: OK 0000
17-in-1 instrument -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-way immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-door electric passenger side door - Status: OK 0000.
55-Beam adjustment. -- Status: OK 0000
56-Radio -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
72- Door, electric, high, right side -- Status: OK 0000
76-Parking Assist -- Status: OK 0000
Address 01: Engine, Label file: RKS\06F-907-115-AXX.lbl
Part number SW: 1Z0 907 115 D, HW: 8P0 907 115 B.
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial Number: SKZ7Z0H4983098
Encoding: 0203000318070160
Operating number: WSC 01286 386 08256
No errors found.
Readiness: 0000 0000
Address 03: Brakes (-----)
Label file: RKS\1K0-907-379-60EC1F.clb
Part number SW: 1K0 907 379 AE, Part number HW: 1K0 907 379 AE.
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Encoding: 143B601C092300FB281206E6901B00416D00
Operating number: WSC 73430 790 00000
No errors found.
Address 08: Climate Control/Heating Label file: RKS\1K0-907-044.lbl
Part number SW: 1Z0 907 044 AC
Part number HW: 1Z0 907 044 AC
Component: ClimatronicPQ35 120 0600
Revision: 00120022 Serial Number: 00000000000000
Operating Number: WSC 00000 000 00000
No errors found.
Address 09: Body Control Module
Label file: RKS\3C0-937-049-30-H.lbl
Part number SW: 3C8 937 049 E Hardware: 3C8 937 049 E
Component: On-board network module H54 2602.
Revision: 00H54000 Serial Number: 00000005893534
Encoding: E10E8E3310280432431914000000000000197F065C10000C000000000000
Part number: 1Z1 955 119 C
Part: Wiper 160708 022 0601
Encoding: 00055223
Part number: 1K0 955 559 AF
Component: RLS 300708 046 0204
Encoding: 00208933
No errors found.
Address 15: Airbag
Label file: RKS\1K0-909-605.lbl
Part number SW: 1K0 909 605 AA, Hardware: 1K0 909 605 AA.
Part: Q2 AIRBAG VW8 027 0900
Revision: 11027000 Serial number: 003B5D15KRXW
Encoding: 0020786
No errors found.
Address 16: Steering wheel
Label file: RKS\1K0-953-549.lbl
Part number SW: 1K0 953 549 BN
Part number HW: 1K0 953 549 BN
Component: J0527 051 0101
Encoding: 0000042
No errors found.
Address 17: Combination Instrument
Label file: RKS\1K0-920-xxx-17.lbl
Part number SW: 1Z0 920 842 C, HW: 1Z0 920 842 C.
Component: COMBINATION INSTRUMENT VD1 1612
Revision: V1612037 Serial Number: SKZ7Z0H4983098
Encoding: 0007101
Operating number: WSC 21506 142 55650
No errors found.
Address 19: CAN Gateway
Label file: RKS\1K0-907-530.lbl
Part number SW: 1K0 907 530 Q, HW: 1K0 907 951.
Component: J533__Gateway H16 0202
Revision: H16 Serial Number: 2700K08630044D
Encoding: E9817F0E5002022302
No errors found.
Address 25: Immobilizer
Label file: RKS\1K0-920-xxx-25.lbl
Component: IMMO VD1 1612
No errors found.
Address 37: Navigation (J0506)
Label file: RKS\1T0-035-680.lbl
Part number SW: 1Z0 035 680 A, HW: 1Z0 035 680 A.
Component: RNS-MID H05 1024
Revision: AB001001 Serial Number: SKZ6Z7H7278020
Encoding: 0C0200000000000300
Operating number: WSC 21506 142 93700
No errors found.
Address 42: Door electrical driver
Label file: RKS\1K0-959-701-MAX3.lbl
Part number SW: 1T0 959 701 E, HW: 1T0 959 701 E.
Component: Door Seal 006 1203
Encoding: 0000246
No errors found.
Address 44: Steering Assist
Label file: RKS\1Kx-909-14x.lbl
Part number: 1K1 909 144 M
Component: EPS_ZFLS, Size 074, H08, 1901.
Operating number: WSC 73430 000 90108
No errors found.
Address 46: Comfort System
Label file: RKS\1K0-959-433-MAX.clb
Part number SW: 1K0 959 433 BT, Part number HW: 1K0 959 433 BT.
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial Number: 00000000000000
Encoding: 98801A085283007F3F020D0FC0084FD6907C00
Part number: 1Z0 951 171 A
Component: Tilt Sensor 009 5003
Encoding: 00000000
Part number: 1K0 951 605 D
Component: LIN BACKUP HORN H08 9001
Component: Interior monitoring system 009 5003.
No errors found.
Address 47: Soundsystem
Label file: RKS\1Z0-035-456.lbl
Part number SW: 1Z0 035 456 HW: 532 226 800
Component: SK35-DSP 4 1000
Revision: 4 Serial number: 00042672
Encoding: 0000000101
No errors found.
Address 52: Door electric, passenger side.
Label file: None.
Part number SW: 1T0 959 702 J, Hardware number: 1T0 959 702 J.
Encoding: 0000246
No errors found.
Address 55: Headlight range adjustment.
Label file: RKS\1T0-907-357.lbl
Part number: 1T0 907 357.
Component: Dynamic LWR 0003.
Encoding: 0000007
Operating number: WSC 73430 790 08192
No errors found.
Address 56: Radio (J0506) Label file: RKS\1T0-035-680.lbl
No errors found.
Address 62: Door electric, left/right.
Label file: RKS\1K0-959-703-GEN3.lbl
Part number SW: 1K0 959 703 J, Hardware number: 1K0 959 703 J.
Component: Door Seal 006 1301
Encoding: 0000144
Operating number: WSC 73430 790 1012544
No errors found.
Address 72: Door electric strike, high, right.
Label file: RKS\1K0-959-704-GEN3.lbl
Part number SW: 1K0 959 704 J HW: 1K0 959 704 J
Encoding: 0000144
No errors found.
Address 76: Parking Assist
Label file: RKS\1Z0-919-283.lbl
Part number SW: 1Z0 919 283 C. Hardware: 1Z0 919 283 C.
Component: Parking Assist System, 8-Channel, Part Number H04 0020.
Encoding: 0000001
No errors found.
End.
Translated on 02-09-2026, 10:47.
DieselSchlumpf
Post20-01-2009, 2:09    Subject: Octavia RS TFSI: Top Speed Problem (2008) Quote
What kind of data do you need?
Top speed is a thing of the past. 240 according to the speedometer, 232 according to the engine control unit. icon_evil.gif
The car doesn't have any modifications installed at the moment because Skoda hasn't been able to code the replacement navigation system. (The A-B-T software has been removed.)
Exhaust gas temperature reached around 1000°C.
Boost pressure: 1.8 bar?!
You can find the log here:
http://www.3drc.de/vmax_dreh_druck_temp_.CSV
Performance chart here:
http://www.gravedigga.de/gallery/main.php?g2_view=core.DownloadItem&g2_itemId=32576&g2_serialNumber=1
Translated on 02-09-2026, 11:11.
DieselSchlumpf
Post20-01-2009, 17:28    Subject: Octavia RS TFSI: Top Speed Problem (2008) Quote
Translated on 02-09-2026, 11:12.
Post20-01-2009, 17:33    Subject: Octavia RS TFSI: Top Speed Problem (2008) Quote
"Could you log the behavior of the air mass and lambda values in the problem area? Maybe also try retarding the ignition timing, or have you put any questionable fuel in the tank?"
DieselSchlumpf
Post20-01-2009, 17:38    Subject: Octavia RS TFSI: Top Speed Problem (2008) Quote
I like to click on everything and log everything that might be helpful.
However, there's a lot of redundant information in the measurement blocks, and I'm not sure where everything belongs.
Are there any blocks or a kind of overview available?
Cucumber juice = gasoline? He only gets overpriced V-power 100 octane icon_razz.gif.
(I'm an ADAC member, and it's really cool that they give an LCD TV away as a bonus each year. *G)
Ignition timing retard.
Air mass.
Lambda (there are quite a few values for that, aren't there?)
Sorry if I'm not an expert icon_sad.gif.
Translated on 02-09-2026, 11:13.
mserge
Post20-01-2009, 17:47    Subject: Octavia RS TFSI: Top Speed Problem (2008) Quote
You just need to sit down once and go through all the data blocks (with the engine idling) to see where you can find what you're looking for. It might sound silly, but that's how it is. Every control unit has the information in different blocks, so there's no one-size-fits-all solution to find something. Also, you shouldn't log too many blocks at the same time, as this can introduce too much temporal deviation (latency).
Translated on 02-09-2026, 11:15.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts New log file (with diagram) - "Thinking time" problem A Upload
No new posts Log files related to the "thinking pause" issue when acce... Upload
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Fuel Injector Problem: AFN 99" VP37 Pump Diesel Engine Technology
