Galaxy Heater Diagnosis: Troubleshooting Guide
Post28-07-2008, 8:01    Subject: Galaxy Heater Diagnosis: Troubleshooting Guide Quote
"This weekend, I was working on a 1998 Ford Galaxy using the Interface (Hex+CAN). My VCDS software is up to date. Unfortunately, I can't access the control module for the factory-installed auxiliary heater. I can, however, access the other control modules."
Could it be that Ford has implemented something specific, which is why the control unit is not accessible via VCDS?
Translated on 18-10-2026, 12:14.
christians
Post28-07-2008, 11:28    Subject: Galaxy Heater Diagnosis: Troubleshooting Guide Quote
Ford probably didn't do much there. If the heating system is from Webasto, you need the corresponding software, not VCDS. However, there are still differences between aftermarket and original equipment (OE) heating systems. I believe the issue was more about the communication between the control unit and the auxiliary heater (SHZ), using either a CAN or W-bus.
There used to be threads about this in the OBD section.
Gruß Christian
Translated on 18-10-2026, 12:15.
No new posts DIY OBD Adapter: Build Your Own Diagnostic Tool Troubleshooting & Guides
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary Heater Diagnostics: CD-ROM Guide On-Board Diagnostics (OBD)
No new posts Webasto Heater Diagnosis: Troubleshooting Guide Diesel Engine Technology
No new posts VW T4 Auxiliary Heater: Diagnosis & Troubleshooting On-Board Diagnostics (OBD)
No new posts Galaxy with 277,000 km mileage, deceased. Diesel Engine Technology
